Dutch Brothers - Crazy Eight Lift And K Member Remover #437630
08/14/09 09:59 AM
08/14/09 09:59 AM
Boca Raton, Florida
daveh1971 Offline OP
Boca Raton, Florida
Hi Guys,
I'm going to be pulling the engine and trans from my 71 Challenger for the new 5 speed and refresh the engine and I saw that Dutch Brothers has what they call a Crazy Eight Lift And K Member Remover. It looks like an easy way to do the job from the bottom. However I can't justify spending the $350.00 for using it once or twice.
Here is the link to it:
http://www.crazyeightlift.com/index_files/Page532.htm
I was just wondering if anyone had one out there that I could borrow for a while? Obvously I would pay for the freight to and from I just can't justify spending that money for a one time use. Thanks
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: daveh1971] #437631
08/14/09 10:41 AM
08/14/09 10:41 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Take their pictures and build your own. It looks pretty simple.
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: daveh1971] #437632
08/14/09 03:45 PM
08/14/09 03:45 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I might rent you mine.
It is a lot of money to shell out, but why would I shell it out for you to use for free?
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: daveh1971] #437633
08/14/09 05:14 PM
08/14/09 05:14 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I have one that's available. However, it may be somewhat pricey to ship it from AZ. Not sure if you are aware that there are two assemblies. 1) The K-member and engine dolly portion which allows you to place the K-member, engine and tranny on. 2)The caster/wheels which bolt on to the frame rails which the lift bar connects to. I believe the total cost of the two is $500. Also, if you need the small block attachment, that's another $40 or so.
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: daveh1971] #437634
08/14/09 05:47 PM
08/14/09 05:47 PM
Illinois
Tinman761 Offline
Tinman761  Offline
Illinois
I'm in the same boat as you, I pulling the motor and trans out of my 67 coronet and also have trouble spending that kind of money for a one time shot
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: Tinman761] #437635
08/14/09 06:05 PM
08/14/09 06:05 PM
1fastrunner Offline
1fastrunner  Offline
I did too, but decided to err on the side of caution. I was going to try to fabricate something, but decided to play it safe. I've used it 2 times in and out. I'm hoping I can use it n some more projects down the road.
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: Tinman761] #437636
08/14/09 06:07 PM
08/14/09 06:07 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
You can rent a cherry picker for $50 or less.
I made my own K frame "cart" out of 2x4's doubled up and 4 good casters.(use solid not pneumatic).
Had my engine and trans out several times and have used the same setup on 3 friends cars.
I bought a lift since BUT I still use the cart!
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: daveh1971] #437637
08/14/09 09:16 PM
08/14/09 09:16 PM
Blanchard, OK
Real-Fury Offline
Real-Fury  Offline
Blanchard, OK
Is it really easier to drop the engine out the bottom than to pull from the top? I've only gone from the top so this really sounds foreign to me. They obviously have the suspension removed in the photo to show what it looks like, but doesn't the suspension get in the way dropping out the bottom?
Butch
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: Real-Fury] #437638
08/14/09 09:42 PM
08/14/09 09:42 PM
SE Pa.
LimeliteAero Offline
SE Pa.
the suspension comes out with the engine.
disconnect the upper control arms from the inner fenders and with everything disconnected take the engine out while its sitting on the k-frame.trans should come out too while youre at it.
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: SSAAHemiFan] #437639
08/14/09 09:46 PM
08/14/09 09:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Dutch Brothers - Crazy Eight Lift And K Member Remover [Re: LimeliteAero] #437640
08/14/09 09:49 PM
08/14/09 09:49 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Butch, generally speaking this is the method to use for a restoration or a front end rebuild while redoing the drivetrain. When you've got fresh pain in the engine compartment this is the best way to go.
I still don't understand this reluctance to build your own. This isn't rocket science. Look at the pictures and buy some angle iron and casters.
Re: Dutch Brothers - Crazy Eight Lift And K Member Remo [Re: Jim_Lusk] #437641
08/14/09 11:49 PM
08/14/09 11:49 PM
New State
kidmopar Offline
kidmopar  Offline
New State
My , When dropping out the bottom, the front-end would need re-alignment + bleeding brakes. Torsion bars need removal. 40 years old K - frame bolts "?" Guess I'm "Old school" My biggest hassle is getting hood back on correctly (even though I've previously marked!) Great idea IF you are installing new suspension parts I saw the Dutch Bros. demo @ Van Nuys , California "Spring Fling" and was tempted to buy their very nice set-up , yet same predicament you state Re: ONE(1) time use just does not justify. Then ALL my "Mopar "Buddies" want to borrow ...............
