Holley Dual Feed Fuel Line #437339
08/13/09 10:06 PM
08/13/09 10:06 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
I have a holley 750 with a dual feed fuel line on a 400 but my coil is right in the way of the fuel line,I know iam not the only person with this so what are some ways i can get around the coil? Also what kind of fastener do i use to mount an ecu to my firewall? since i cant get a nut behind it what are my options? Thanks
Re: Holley Dual Feed Fuel Line [Re: 440_ci] #437340
08/13/09 10:11 PM
08/13/09 10:11 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Self tapping screws are the only real option
You can bend some lines to get around the coil. or go hog wild and order the SS setup out of MCG for 45 bucks. Prebent and runs the line away from the coil.
I want my fair share
Re: Holley Dual Feed Fuel Line [Re: SomeCarGuy] #437341
08/13/09 10:18 PM
08/13/09 10:18 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
Thanks alot for that quick reply, does anyone have any pics of their fuel line setup with a holley dual feed? i can spring for pre bent stuff but would prefer to rig something myself.
Re: Holley Dual Feed Fuel Line [Re: 440_ci] #437342
08/13/09 10:37 PM
08/13/09 10:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Heres an option... I need to go back and clean it up but not bad for a quicky job... The coil bracket is a piece of 1" 12ga flatbar with three holes drilled in it one for a manifold bolt & two for the std coil bracket...The fuel line is patterned after the stock sixpack & hemi style lines & fittings..
Re: Holley Dual Feed Fuel Line [Re: 440_ci] #437343
08/14/09 04:08 PM
08/14/09 04:08 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
There is a guy named Greg out of Colorado that sells 2 neat products, 1 is a hard fuel line for a dual-feed Holly and the other is a coil mounting bracket moving it forward for clearance. Both are of high-quality already fabricrated. I was going to make my own and until I found these, they work well highly recommended.
His # is 303_666_9882
Just my $0.015...
Re: Holley Dual Feed Fuel Line [Re: Sinitro] #437344
08/14/09 04:27 PM
08/14/09 04:27 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I used a Ford(sorry) coil bracket on mine. It's a loop bracket and only uses one bolt hole. I think I have a spare if you need it. A buddy used a six pak coil bracket on his.
1981 Dodge D150 360 auto
