MW vs. Strange vs. ??? for axels... #436915
08/13/09 05:18 PM
08/13/09 05:18 PM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
Looking to beef up my 8 3/4 over the winter and wanted some feedback here.
It currently has stock axels, 3.91 gears, locker type, and green bearings. It is in my 67 Coronet, 470, 727 trans w/ a 3k converter, current best is 12.1 @ 112.42, 1.68 60' on M/T drag radials (and would like to use slicks in the future).
I'm looking to beef up the rear and install new axels, but am not sure what to select. I'm not looking to make this into a 10 second car... maybe an 11.20's car by next summer.
So, which ones should I use? MW? Strange? Any other brands I am not aware of? Anything else I should be aware of?
Thanks for your input. I appreciate it!
Re: MW vs. Strange vs. ??? for axels... [Re: 67dodge67] #436916
08/13/09 05:20 PM
08/13/09 05:20 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Well....you say you dont want it a ten second car, but some day you might.
I would go with the best you ultimatly can afford. As far as the major brands, which ever works out to the best deal. They are all so similar, there are plenty of people that can put you onto a good deal just keep an open mind.
I ran well into the 10s with the 8.75, wasnt until I put alky injection into it. It didnt make it past the 60 ft. Heck didnt even leave the beams before it broke.
Re: MW vs. Strange vs. ??? for axels... [Re: Garceau] #436917
08/13/09 05:26 PM
08/13/09 05:26 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Try Moser. They have excellent customer service and are contingency payers.
Re: MW vs. Strange vs. ??? for axels... [Re: Garceau] #436918
08/13/09 05:29 PM
08/13/09 05:29 PM
MW are excellant but there splines on their axles are not interchangeable with other manufacturers products,
i went with moser on the axles because there customer service is excellant.
Strange is also a good company but there customer service stinks and its hard to order from them,
you cant just give them dimensions and order,they ask how and why ? making ordering from them very difficult, its not a easy process.
as far as driveshafts MW hands down.
Moser is my choice for axles, you wont go wrong but go with 35 spline.
Re: MW vs. Strange vs. ??? for axels... #436919
08/13/09 05:52 PM
08/13/09 05:52 PM
Moser the "best" out there...
Re: MW vs. Strange vs. ??? for axels... #436920
08/13/09 06:33 PM
08/13/09 06:33 PM
illinois,u.s.
beezer Offline
beezer  Offline
illinois,u.s.
MW for sure. I had a problem with a set of axles that I had ordered from MW in that one was the wrong length. MW hisself got on the phone told me to send it back freight collect,next day aired me the right size axle on his dime too.
Re: MW vs. Strange vs. ??? for axels... [Re: 67dodge67] #436921
08/13/09 07:03 PM
08/13/09 07:03 PM
To make the 8 3/4 live in your car plan on installing a steel cap on the drivers side of the carrier and a set of axles and spool that are 35 splines. You will need the axle wheel bearings for those axles also I lke the "742" carrier best and then the "489" and last the "741" due to the differences in the pinion shaft diameter at the front bearing
Re: MW vs. Strange vs. ??? for axels... [Re: Cab_Burge] #436922
08/13/09 07:27 PM
08/13/09 07:27 PM
WI, USA
mopar addict
mopar addict
WI, USA
Thanks for the replies here. One thing I forgot to mention, the car is primarily a street car and will see about 25% time on the strip. Therefore, is a spool the best choice? I have heard it is not if the car will be driven on the street.
Anyone else for input on axels and the such? Thanks for all the info here.
Re: MW vs. Strange vs. ??? for axels... [Re: 67dodge67] #436923
08/13/09 07:40 PM
08/13/09 07:40 PM
a spool is a little tough on the street but doeable.
if you plan on making a few tricks to the track, go for the spool.
i ran a spool on the street for years just go easy around turns.
Re: MW vs. Strange vs. ??? for axels... #436924
08/13/09 08:31 PM
08/13/09 08:31 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have Strange axels and have had zero problems with them or there service when I ordered them I wasn't sure on 1 of the measurements they needed so the rep call Aerospace for me to make sure the axels where correct I just sent them back last week to get the lug pattern redrilled to the large 5/8x18 studs they got them late Monday and called me on Tuesday to tell me they where shipping out WOW 1 day service what more can I ask for
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: MW vs. Strange vs. ??? for axels... [Re: 67dodge67] #436925
08/13/09 08:34 PM
08/13/09 08:34 PM
NC
440Jim Offline
440Jim  Offline
NC
There are stronger axles than Moser Engineering out there, but for your application a set of ME 35 spline will be stronger than the rest of your rear. But that will require changing the carrier to get 35 splines. If you are keeping the lesser strength splines, buy the cheapest (new) axles you can since the spline will be weak.
Re: MW vs. Strange vs. ??? for axels... [Re: 440Jim] #436926
08/13/09 11:45 PM
08/13/09 11:45 PM
ky
68roadrunner Offline
ky
if the springs are moved in, or ladder bars. you might consider a back brace.
Re: MW vs. Strange vs. ??? for axels... [Re: 67dodge67] #436927
08/14/09 12:34 AM
08/14/09 12:34 AM
AndyF Offline
AndyF  Offline
Talk to DoctorDiff about axles. He had a batch of axles made last year that should work for you but you'll have to check with him on spline counts and such.
Re: MW vs. Strange vs. ??? for axels... [Re: AndyF] #436928
08/14/09 12:39 AM
08/14/09 12:39 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Mark Williams will spline axles to suit any spool using the 30 pressure angle. Mark Williams stuff has a 45 degree pressure angle usually.
Moser stuff is strong, but not finished to the same standard that MW stuff is. You get what you pay for. In most cases, the Moser stuff is OK
AL....
Alan Jones
Re: MW vs. Strange vs. ??? for axels... [Re: LA360] #436929
08/14/09 05:51 AM
08/14/09 05:51 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I really like Moser, great customber service to boot. Dave
Re: MW vs. Strange vs. ??? for axels... [Re: quickd100] #436930
08/14/09 08:28 AM
08/14/09 08:28 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cantact Dr Diif he is a member and I believe he even makes his own axles.He carries a lot of stuff.He has a 4 sale add in the rear end section here.Rocky
Chrysler Firepower
Re: MW vs. Strange vs. ??? for axels... [Re: therocks] #436931
08/14/09 09:52 AM
08/14/09 09:52 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Mark Willaims over Moser every time. Strange Over Moser every time, al though I wont hesitate to put a set of Moser axles in a 3000 lb 9 second ride.
Re: MW vs. Strange vs. ??? for axels... [Re: 68roadrunner] #436932
08/14/09 02:26 PM
08/14/09 02:26 PM
WI, USA
mopar addict
mopar addict
WI, USA
my springs are moved in 3 inches... never thought about the back brace.... even running low 11's?
Re: MW vs. Strange vs. ??? for axels... [Re: therocks] #436933
08/14/09 02:27 PM
08/14/09 02:27 PM
WI, USA
mopar addict
mopar addict
WI, USA
I have done business with Dr. Diff before - front disk brake kit - and know he is very reliable. Point taken... Thanks.
Re: MW vs. Strange vs. ??? for axels... [Re: 67dodge67] #436934
08/14/09 02:29 PM
08/14/09 02:29 PM
WI, USA
mopar addict
mopar addict
WI, USA
Someone here made a comment about MW drive shafts. I'll be replacing my stock one as well when doing this. Yes or No to them for their drive shafts?
Thanks again for all the input here!!
