Replacement of Door Hinges #436906
08/13/09 05:02 PM
08/13/09 05:02 PM
Nunya CA
CR8CRSHR Offline OP
CR8CRSHR  Offline OP
Nunya CA
Quick Question...I just received my replacement door hinges for my 66 Plymouth Satellite project. I have a factory Service Manuel [FSM] and the procedure/technique is not going to be a problem understanding. However...there is no mention as to if I need to remove the doors along with the fenders completely or can I accomplish this one hinge at a time with everything attached. Granted it would be easier if the fenders were removed but with the door open and supported I can get to all the attaching bolts. What have any of you all found to be the easiest and most solid way of doing this. The car has already been painted so I guess you could say I didn't plane to get this part of the project done before painting. As always MOPARTS rules.....
Re: Replacement of Door Hinges [Re: CR8CRSHR] #436907
08/13/09 05:25 PM
08/13/09 05:25 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
open the door, put a floor jack under the door with a 2X4 to protect the bottom of the door. Jack it up only to support the door. Replace the top, then replace the bottom.... Done
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Replacement of Door Hinges [Re: Noblewk] #436908
08/13/09 07:17 PM
08/13/09 07:17 PM
Andrewh Online content
Andrewh  Online Content
there is a door support thing/cradle that pins to a floor jack. It is padded and prevents the door from moving.
Using that and some of that foam pipe insulation, I pulled the door to do work on my hinges.
To remove them looked like the fender had to go, but that is on an early b.
Re: Replacement of Door Hinges [Re: Andrewh] #436909
08/14/09 08:08 AM
08/14/09 08:08 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just did them on my 65.No need to remove the fender.Its tight but you can remove all the bolts.Some are inside the kick panel.I did one at a time with my floor jack and my kid helping.Rocky
Chrysler Firepower
Re: Replacement of Door Hinges [Re: therocks] #436910
08/14/09 01:36 PM
08/14/09 01:36 PM
Nunya CA
CR8CRSHR Offline OP
CR8CRSHR  Offline OP
Nunya CA
Thanks Guys...It looks like a doable process to me. I am fabing up a cradle out of wood for the door support and jack. Again MOPARTS rules....
