1967 gtx grill #436564
08/13/09 09:13 AM
08/13/09 09:13 AM
maryland
jackassjeeper97 Offline OP
maryland
Anyone have a close up of a 67 gtx grill painted correctly they could post? Thank you James
Re: 1967 gtx grill [Re: jackassjeeper97] #436565
08/13/09 12:07 PM
08/13/09 12:07 PM
OR
AllTrim Plus Offline
OR
Will an NOS grille work?
Re: 1967 gtx grill [Re: AllTrim Plus] #436566
08/13/09 01:23 PM
08/13/09 01:23 PM
maryland
maryland
Yes Thank you
Re: 1967 gtx grill [Re: jackassjeeper97] #436567
08/14/09 09:04 AM
08/14/09 09:04 AM
Ontario,Canada
1967GTX440 Offline
1967GTX440  Offline
Ontario,Canada
Hi I just painted the grill and head light bezels in my 67 GTX it turned out perfit I used the argent silver from Totally Auto in Penn.They sell the correct colour of silver argent for 67.Sorry I can't post a picture not very good with pic. from camera to PC and attaching.
Re: 1967 gtx grill [Re: AllTrim Plus] #436568
08/16/09 08:19 AM
08/16/09 08:19 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
No offense to the NOS grille, but use caution when viewing only one photo for a correct restoration without further clarification. Various details and 'argent' colors can be misleading to a viewer due to light reflections, flash, etc. (I have no doubts about AllTrim's experience and reputation).
HEADLIGHT DOORS:
- The headlight doors seem to be missing the small horizontal aluminum trim between the centers of the headlight pairs.
- The (3) horizontal stripes above and below this trim piece appear 'clear' aluminum in the photo, but they are supposed to be dark argent to match the horizontal ribs of the center grille.
- AllTrim - can you verify what argent is inside the rim of each headlight opening? Is it dark argent?
- For reference, this appears correct in the photo: The outside stripe aroudn the headlight doors (and hood egde modling) is dark argent.
CENTER GRILLE SECTION:
- The 'Red-White-Blue' center emblem appears missing. Maybe it's the way light is reflecting.
- The main horizontal center bar is clear aluminum and matches up with the (missing?) aluminum tabs between the headlights.
GENERAL NOTE:
- The only paints used on the front grille of a '67 GTX are black and dark argent. The only other finish is clear aluminum. There's no light argent, and no white.
I'm not perfect, so feel free to comment.
Best,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 1967 gtx grill [Re: 67SATisfaction] #436569
08/16/09 12:47 PM
08/16/09 12:47 PM
OR
OR
the OP wanted to know about the detail (paint i guess), the grille pictured is an untouched NOS grille sprayed by the factory that supplied to mopar (who ever that was?).
yes the lines on the grille are argent (this new pic shows it better), yes the headlight openings are argent (same as grille). yes the long bar in the center of the grill is bright anodized. there is no light silver non textured argent anywhere on the grille if it looked that way from the lighting?
the guy that sent this in kept his emblem and the tabs from the headlight bezles. it was sent in for restoration because of scratches in the anodized finish from 30 years of being without a box.
Mike
