Weather Stations #436515
08/13/09 09:47 AM
08/13/09 09:47 AM
Out West
408strokerdart Offline OP
Out West
Does anyone run a trailer mounted weather station and if so what brand? I am looking at an altronics trailer mounted unit hooked to my laptop using the crew chief pro software. Can anyone recommend any better bang for the buck out there? I really just need something that is a good et predicter in varying weather conditions.
Re: Weather Stations [Re: 408strokerdart] #436516
08/13/09 09:59 AM
08/13/09 09:59 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Crew Chief pro is very good software. I had an older version back in 03 and the stuff it could do then was amazing. I can only imagine what he has come up with now. Great people to deal with as well, all racers.
His system works well and wins lots of races, plus it has the added benefits of run tracking, expenses, tech card print outs etc....
Re: Weather Stations [Re: Garceau] #436517
08/13/09 10:22 AM
08/13/09 10:22 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Family Software Crew chief pro gives 4 predictions and you can guess which one to use. family Software one prediction within .002
I use the pager system which you can have page you as often as you want in case your sitting in the lanes for a hour.Also it logs everything for you.
Re: Weather Stations [Re: Garceau] #436518
08/13/09 10:44 AM
08/13/09 10:44 AM
Northeast Texas
MoparMuscle Offline
MoparMuscle  Offline
Northeast Texas
I use the Altacom with pager, anemometer and Crew Chief Pro software. Works really well.
100% Mopar No Juice Added
2016 Challenger R/T Blacktop 5.7 6 SPD
2009 Ram 1500 5.7
http://moparmuscle.biz
Re: Weather Stations [Re: MoparMuscle] #436519
08/13/09 10:59 AM
08/13/09 10:59 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use a wet finger in the air
Seriously a trailer mounted weather station is on my to get list. Lord knows the finger is a little inaccurate sometimes.
Re: Weather Stations [Re: Al_Alguire] #436520
08/13/09 11:04 AM
08/13/09 11:04 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'm currently using a Speed Tech weather meter and looking to step up to a Tag. I want one that will give me the weather at the line. Not the trailer. You'd be surprised how different the weather can be in just that short distance.
Re: Weather Stations [Re: WILD BILL] #436521
08/13/09 11:09 AM
08/13/09 11:09 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
This is where you are wrong, you dont want the weather conditions at the line.You would be better off having someone at your trailer calling you on a cell phone with the weather as when you leave the line it changes.
Re: Weather Stations [Re: cudabunch] #436522
08/13/09 11:27 AM
08/13/09 11:27 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Or have someone standing in the middle of tthe track @ the 1/8th
Re: Weather Stations [Re: WILD BILL] #436523
08/13/09 11:43 AM
08/13/09 11:43 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Bill, the temp at your trailer is what it is, unless you have the speed tech setting in the sun or let the radiant heat from blacktop get to close.This is why the trailer mounted are better because they use a fan inside to get the real conditions. I have seen the hand helds with the fan inside but it would have to be put up high to stop the radiant heat from affecting them.The heat from the engine will also affect the air into the carb and this is why you see a car pick up by sealing the carb,its cooler air.
Re: Weather Stations [Re: cudabunch] #436524
08/13/09 11:55 AM
08/13/09 11:55 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I was refering more to humidity and pressure being different. Humidity more than pressure.
I use it mostly for the Jr as Hum can have a great impact on fast it will run.
I guess the main thing in what ever weather staion you use is use it consistantly.
Re: Weather Stations [Re: WILD BILL] #436525
08/13/09 12:11 PM
08/13/09 12:11 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Yeah I understand what your saying and maybe Iam not explaining it well. The Temp at the line is always higher because of the cars and people and burnouts.The temp at your trailer is the actual temp - down track. Leave it at the trailer.I watch people at the track putting the hand helds on the roof of cars in the sun and they dont read correct.Soon as you leave the line the temp changes.Sorry if this is to long.
Re: Weather Stations [Re: cudabunch] #436526
08/13/09 12:40 PM
08/13/09 12:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I carry mine with me and take my reading in the lanes
before I strap in.... if you do the SAME thing
all the time it doesnt matter, you enter the ET based
on where you took the reading... but the car is using
the air thats on the track not back where all the
grass and trees are(if your that lucky)
Re: Weather Stations [Re: MR_P_BODY] #436527
08/13/09 12:49 PM
08/13/09 12:49 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Would'nt the weatherstation change with the amount of cars in the lane? More cars running and as the day goes by there's less?
Re: Weather Stations [Re: Hunted Duck] #436528
08/13/09 12:56 PM
08/13/09 12:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I usually walk up near the line and take the reading
and check the wind then go back and write it on....
the unit I have doesnt have a wind meter so I check the
flags for speed and direction then based my Tag reading
adjust it for wind
Re: Weather Stations [Re: MR_P_BODY] #436529
08/13/09 01:28 PM
08/13/09 01:28 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
adjust it for wind
Racerv351 Yes it would change it.When you have a hundred cars producing heat in the line of course it will affect it. The closer to the line the more the temp goes up, but leaving it changes.A easy way to find out is to take a reading at the line and then down track and see if its the same.It will not be the same.
Mr P You leave in bad air and it gets better and it would be the same air as your trailer reading if you have a fan in your unit which I believe the Tag does.Take a reading from your trailer and the track and see if its the same as the line,or staging lanes.If your dialing in from the line I will guarntee you will be more consistant from the trailer.Give it a shot and if Iam wrong come on here and tell me so.
Re: Weather Stations [Re: cudabunch] #436530
08/13/09 01:37 PM
08/13/09 01:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've checked it at the trailer VS the line and yes
they are different but you cant tell me which is
more correct... might be fine if your trailer was
parked at 1/2 track along the fence closest to the track.
Either way if you take the SAME readings all the time
its immaterial... just as long as its the same way
Re: Weather Stations [Re: MR_P_BODY] #436531
08/13/09 08:25 PM
08/13/09 08:25 PM
Out West
Out West
bump for the evening crowd.
Re: Weather Stations [Re: 408strokerdart] #436532
08/13/09 08:28 PM
08/13/09 08:28 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
As stated doesnt matter where its taken, as long as its the same each time. I have done both.
But I hold several numbers so it really doesnt matter too much. But when I was T-stop racing it was VITAL. I loved my crew chief pro.
In the 10.90 race I won at the CFR divisional, it ran 10.902 in the semis, and 10.902 in the finals.
Re: Weather Stations [Re: Garceau] #436533
08/13/09 09:51 PM
08/13/09 09:51 PM
Huron, South Dakota, United St...
dustyhof Offline
dustyhof  Offline
Re: Weather Stations [Re: dustyhof] #436534
08/15/09 09:23 AM
08/15/09 09:23 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
Your trailer will never be far enough away from the track to make any difference in weather. Your not racing at the trailer or the lanes, your looking for consistent readings with the least amount of artificial influences. Taking it in the lanes or at the line will never be as consistent as a trailer mounted unit. There are too many variables in the lanes, # cars, location of the sun, radiant heat off the asphalt will vary with sun location, clouds, etc. There will be less artificial disturbances at your trailer.
