Re: Engine Limiters..
[Re: gearjammerdart]
#436302
08/12/09 11:55 PM
08/12/09 11:55 PM
I would put one on it, I usually go from the boss on the drivers side down to the top of the K member. This is to limit it front to back. I'm assuming that your not using the stock mounts. Donald
Got any pics
#436303
08/12/09 11:57 PM
08/12/09 11:57 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
NO its got a motor plate plus mid plate plus the passenger side soild mount...
[Re: 70dusterjohn]
#436304
08/12/09 11:59 PM
08/12/09 11:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've got a motor plate with a mid plate.. Do I need to put limiters on this.. Okay little more info. the duster has a stock big block k member in it out of a 68 Dart so the motor mounts are still on it.. well at least the passenger side.. Whatca think...
Multiple ways of doing it... I prefer 2 limiters but thats me(can eliminate twist) but you can use a rod from the engine mounts on the block to the frame rails or you can come off the trans ears to the rails thats just a couple
[Re: 70dusterjohn]
#436306
08/13/09 12:09 AM
08/13/09 12:09 AM
MR_P_BODY
So you think that I need them even if I'm still running the passenger side mount soild..
Sorry, I dont know for fact... but I have heard of guys breaking the ears off of the engine with solid mounts(but thats all they were using, no motor plate)
[Re: 70dusterjohn]
#436308
08/13/09 12:16 AM
08/13/09 12:16 AM
MR_P_BODY
I guess it wouldn't hurt to throw a couple on it.. Thanks Mr P Body..
To be honest I would cut off all of the motor mounting stuff and just use limiters... you save weight and clear that area
