Cam Choice
#436217
08/12/09 09:37 PM
08/12/09 09:37 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
Time to plan the winter rebuild. This is for my 440 Dart bracket car. Ported Edelbrock Performer heads (300 cfm @.600) 1.6 rockers 11/1 compression EFI with tunnel ram 2" Pro-Parts headers 3000 lbs w/driver 4.10 gear 30 inch tire 5200 stall Car has run a best of 10.21 with a Scott Brown flat tappet I want to step up to a solid roller Would love to dip into the nines Any suggestions??
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
Re: Cam Choice
[Re: AndyF]
#436219
08/13/09 07:56 AM
08/13/09 07:56 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Give Dwayne at Porter Racing Heads a call and let him supply with the cam/lifters/springs that you'll need. That way you'll only need to spend the money once.
He is THE cam guru. 802-951-1955 CHIP
Re: Cam Choice
[Re: Brian Hafliger]
#436222
08/13/09 10:36 PM
08/13/09 10:36 PM
Dave_S
The rockers are 1.6 roller
The current cam is a solid flat tappet 259/268 @.050 287/297 Advertised duration .625/.608 112 lobe centers
Re: Cam Choice
[Re: Dave_S]
#436223
08/14/09 12:20 AM
08/14/09 12:20 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
What brand of rockers??
