Cam Choice #436217
08/12/09 09:37 PM
08/12/09 09:37 PM
Burlington, Ontario Canada
Dave_S Offline OP
Dave_S  Offline OP
Time to plan the winter rebuild.
This is for my 440 Dart bracket car.
Ported Edelbrock Performer heads (300 cfm @.600)
1.6 rockers
11/1 compression
EFI with tunnel ram
2" Pro-Parts headers
3000 lbs w/driver
4.10 gear 30 inch tire
5200 stall
Car has run a best of 10.21 with a Scott Brown flat tappet
I want to step up to a solid roller
Would love to dip into the nines
Any suggestions??
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Cam Choice [Re: Dave_S] #436218
08/12/09 11:19 PM
08/12/09 11:19 PM
AndyF Offline
AndyF  Offline
Give Dwayne at Porter Racing Heads a call and let him supply with the cam/lifters/springs that you'll need. That way you'll only need to spend the money once.
Re: Cam Choice [Re: AndyF] #436219
08/13/09 07:56 AM
08/13/09 07:56 AM
an8sec70cuda Offline
He is THE cam guru. 802-951-1955 CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cam Choice [Re: Dave_S] #436220
08/13/09 09:23 PM
08/13/09 09:23 PM
SoCal
Brian Hafliger Offline
SoCal
1.6 rockers
11/1 compression
EFI with tunnel ram
3000 lbs w/driver
5200 stall
Any suggestions??
What kind of rockers are you using? What are the specs of the current cam?
Brian Hafliger
Re: Cam Choice [Re: Brian Hafliger] #436221
08/13/09 09:34 PM
08/13/09 09:34 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Dave Phone scott!
Re: Cam Choice [Re: Brian Hafliger] #436222
08/13/09 10:36 PM
08/13/09 10:36 PM
Dave_S Offline OP
Dave_S  Offline OP
The rockers are 1.6 roller
The current cam is a solid flat tappet
259/268 @.050 287/297 Advertised duration
.625/.608 112 lobe centers
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Cam Choice [Re: Dave_S] #436223
08/14/09 12:20 AM
08/14/09 12:20 AM
SoCal
SoCal
What brand of rockers??
Re: Cam Choice [Re: Brian Hafliger] #436224
08/14/09 08:38 PM
08/14/09 08:38 PM
Dave_S Offline OP
Dave_S  Offline OP
The rockers are from Hughes
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Cam Choice [Re: Dave_S] #436225
08/14/09 09:14 PM
08/14/09 09:14 PM
NC
440Jim Offline
440Jim  Offline
NC
I think the old cam was a pretty good choice. Your 11 CR will limit the amount of duration I would put in it. Maybe 10 degrees more at 0.050" at the most. But with a roller profile, you can add more lift.
How would you describe the current performance? ie launch power, mid track, top end mph, etc.
Re: Cam Choice [Re: Dave_S] #436226
08/14/09 10:10 PM
08/14/09 10:10 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Good luck
Mopar Performance
Re: Cam Choice [Re: moparniac] #436227
08/17/09 03:01 PM
08/17/09 03:01 PM
Dave_S Offline OP
Dave_S  Offline OP
Got a call in to Scott Brown. will post the reply
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
