Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436088
08/13/09 11:39 PM
08/13/09 11:39 PM
Jack the car up and put it on four jackstands so the car is as near to level as it is on the road, run it up slowly in gear and identify what RPM and or speed the vibration is at. Remove the wheels and tires (make sure to either remove the brake drums and don't touch the brake pedal whie thier off ) and check it again. If the vibrations are still there look at the driveshaft, pinion angle and so on let us know what you find. BTW, Make sure the jack stands are under the rear end housing to test, not under the frame with the rear end hanging down on the springs and shackles
Re: Demons got "VIBRATIONS" [Re: Cab_Burge] #436089
08/14/09 12:02 AM
08/14/09 12:02 AM
Finally a HUSKER again
Moparnut426 Offline OP
I know the pinion is the problem, I just said the floor, and my pinion are equal as a referance. The shaft basically is dead straight from trans to punkin. Its not good, and I know I need it corrected. Ill be busy in the morning, but I got to get it to Kearney for Reed Koeppe's flat landers fling this weekend.
Kasey
Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436090
08/14/09 03:37 PM
08/14/09 03:37 PM
Well, I set my pinion angle 4* down from where it was, and I checked the ballance on the rear wheels, They were off by 2+ oz each. Still vibrates like crazy, I dont feel safe trying to make a maiden voyage down the strip with nast bad vibrations under power at high speeds, so Im just gonna trailer my car to Kearney to check out the cool Old scool cars there, and enjoy a stress free weekend.
Im starting to think I might have something in the tranny causing greef and racket, but I wont dig into that till I pull the engine for the stroker.
Thanks guys for all the sugestions, and help.
Kasey
Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436091
08/14/09 05:36 PM
08/14/09 05:36 PM
OK, now Im just PIZZED beyond belief...
I just spent over 350 bucks, 370 after freight on a new ballenced drive shaft, and after pulling my hair out trying to find the vibration, I checked mounts, set pinion angle, ballenced wheels, checked brake drums, free revved the engine to 3800, you name it, I finally said to myself, I better check the only thing different. The driveshaft I just bought. ITS FREEKING WELDED 3/16 OUT OF ROUND ON THE FRONT YOKE!!!
Needless to say I wont be racing at all this weekend. I guess thats what I get when I order a shaft from a dirt track company who specialise in chevy style shafts.
When I got the thing, the front yoke felt funny, and had a catch in it. I noticed one of the caps wasnt pushed all the way in. I saw one of the snap rings was over the cap, not in the groove. Chevys are outside snap ring style, so If this guy is use to building these, I can see the possibility of it being wacko. But anyhow, I now know what happened. He probably had the yoke, and the ujoints together, WRONG, then tacked them up, but probably spun up the shaft before welding solid, and since one cap wasnt in correctly he compensated fo this by offsetting his yoke into the tube. If I wouldnt have inspected it, and ran it it wouls have been ok untill the u-joint flew appart.
I understand SH*T happens, but I really wanted to run my car this weekend...
Oh well.....
I can cruise for a bit, I still have heating issues to deal with too.
Kasey
Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436092
08/14/09 06:33 PM
08/14/09 06:33 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Sorry the way things turned out for you this weekend. I wish you lived closer as I have several shafts laying around. Post the length you need and maybe someone can help out.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Demons got "VIBRATIONS" [Re: pittsburghracer] #436093
08/14/09 06:37 PM
08/14/09 06:37 PM
My shaft is 49.5", maybee couldnt hurt to be a snippy shorter, but I have 49.5 ". It has 7290 joints in it.
Kasey
Thanks!!!!
Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436094
08/14/09 07:36 PM
08/14/09 07:36 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
they did a good job balancing the driveshaft after building it
i would put it thru their front window
Re: Demons got "VIBRATIONS" [Re: sixpackgut] #436095
08/14/09 07:49 PM
08/14/09 07:49 PM
TRUST ME,,, Id love to.
Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436096
08/17/09 07:23 PM
08/17/09 07:23 PM
Well I got the Demon up on the hoist today, got out my dial indicator and spin wheel tip, measured the tranny end. Its over .075" out of round. Thats terrible, and I can not believe this passed any quality control at all!!
Im very upset, and I really dont know If Im gonna have them build me a new one, or get my $$$ back and go strange, or mark williams.
Kasey
Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436097
08/17/09 10:06 PM
08/17/09 10:06 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
whered the shaft come from ?
Re: Demons got "VIBRATIONS" [Re: sogtx] #436098
08/17/09 10:09 PM
08/17/09 10:09 PM
Its a "FAST SHAFT" from a shop in Iowa. They are well known in the dirt car world, and my buddy has been flogging on one for years, and The race shop I bought mine from highly recomended mine. I on the other hand do not... I realize sh#t happens, but why me???
Kasey
Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436099
08/17/09 11:50 PM
08/17/09 11:50 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Is it the drive shaft or the trans main out put shaft? u-joint? Hate to see you trashing somebody's product if it's not the problem. I had two out put shafts bent on two different transmissions. Could be that I drop the clutch at to low of rpm's
Re: Demons got "VIBRATIONS" [Re: rowin4] #436100
08/18/09 07:16 AM
08/18/09 07:16 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
dennys is a better place to get one ..
Re: Demons got "VIBRATIONS" [Re: rowin4] #436101
08/18/09 09:23 AM
08/18/09 09:23 AM
Its the shaft fore sure... I measured run out on the tube, and the yoke its self out of the trans, there is nothing at the slip yoke, and the tube is very obvious. You dont need to measure it, too see the wobble. I didnt think I was thrashing them too bad, I know crap happens, I just wouldnt racomend them right now. I see Dennys has a shaft for the same money, and I have seen MANY of them on the drag strip.
Kasey
Re: Demons got "VIBRATIONS" [Re: Moparnut426] #436102
08/21/09 06:06 PM
08/21/09 06:06 PM
Got my shaft back, Its only got the typical "im going 110mph in a 1971 model mopar" vibration now, but is smooth as silk at 60 through 80 on my speedo which is not accurate I have found out via state patrol.
The guys at Fast shafts were good to me, and said "sorry for the F up" and have a nice day. It still had anout .010 of run out in it, but That coud be a number of things with an old 833.
Kasey
