Demons got "VIBRATIONS"
#436068
08/12/09 07:33 PM
08/12/09 07:33 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
So now that the car is moving, and I have things moving in the straight and narrow. I have been driving the car more, and working out heating bugs, tuning bugs, and I had a vibration, well still do. I bought a new driveshaft because the one in there was a homemade cobbled up shaft. The engine was balenced with damper, flywheel, but not clutch. I have an 833 that was well used. At higher speeds I get a pretty bad vibration, I mean verry noticable speed related vibration. Driveshaft is new, gears are new 3:91s. I balenced the wheels/tires 1.5 years ago when boughten. What could be the problem guys. I know I have been on here a lot lately, but you guys have been pretty spot on on everything so here is another one for ya.
Kasey
Re: Demons got "VIBRATIONS"
[Re: rowin4]
#436074
08/12/09 09:10 PM
08/12/09 09:10 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you changed anything in the rear suspension recheck your pinion angle. 25+ years ago I put super stock springs on the rear of my 72 duster. I had a high speed vibration and went crazy trying to find it till I read about pinion angle. When I changed the springs my pinion angle ended up at 5-10 degrees nose up. I lowered the pinion back where it should be and the vibration was gone.
[Re: Moparnut426]
#436077
08/12/09 10:09 PM
08/12/09 10:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Kasey
You say SPEED related so that leaves the clutch out or you could bring the engine RPM up and it would occur.... I would have the tires and wheels balanced first... you need to start eliminating things, doing the easiest first
[Re: rowin4]
#436078
08/12/09 10:36 PM
08/12/09 10:36 PM
Moparnut426
Ok, the rear end has everything new. I rebuilt the center, and it has green bearings. The Tires are definatly not flat in spots, I make sure if it does set its off the ground. The only thing Im thinking is the rearend is out of a truck, and I cut and moved the pads 10 years ago before I even knew what a pinion angle it. I know I measured before and after when putting them back on, but I was 16 years old ish when I did it. Im going to check that first. Then I might take my wheels in and ballence them again. It definatly rear oriented.
Also I just got done putting a new yoke in the rear from Mancini, its the nice billet steel one. Sooooooo, new shaft, rebuilt tranny, new gears, new rear bearings, new u joints, new output bushing, new front yoke, new 11" rear drums, new green axle bearings, and I did exactly what mopar told me on measuring my shaft. I had vehicle weight on cal, measured from 1 inch from bottoming out in tail shaft, and to the center of the rear yole. Center to center was 49 3/8 ish.
Im hopeing on the pinion angle... Thanks guys
Kasey
[Re: Moparnut426]
#436087
08/13/09 11:30 PM
08/13/09 11:30 PM
MR_P_BODY
so my pinion angle is 0, maybe 1 posotive, my floor is reading 0, my rearend reads the same at my pinion flange. thats bad, and probably my vibration, or what my dad calls knuckle knock.
kasey
The floor has NOTHING to do with checking the pinion angle.... there are 2 theories how to check it 1) take a reading from the tailshaft output then read the pinion, it should be about 5* down from the trans number(for a left set up) 2) read the drive shaft and put the pinion 5* down from that(easy way to do this one is to use a socket that fits the U-joint cup then use the inclinemeter/ angle finder on the socket then read it, now turn the driveshaft 90* and do the same thing, the difference is angle)... this is done with the car weight on the diff but it can be up in the air... both front and rear
[Re: Moparnut426]
#436090
08/14/09 03:37 PM
08/14/09 03:37 PM
Moparnut426
Well, I set my pinion angle 4* down from where it was, and I checked the ballance on the rear wheels, They were off by 2+ oz each. Still vibrates like crazy, I dont feel safe trying to make a maiden voyage down the strip with nast bad vibrations under power at high speeds, so Im just gonna trailer my car to Kearney to check out the cool Old scool cars there, and enjoy a stress free weekend.
Im starting to think I might have something in the tranny causing greef and racket, but I wont dig into that till I pull the engine for the stroker.
Thanks guys for all the sugestions, and help.
Kasey
[Re: Moparnut426]
#436091
08/14/09 05:36 PM
08/14/09 05:36 PM
Moparnut426
OK, now Im just PIZZED beyond belief... I just spent over 350 bucks, 370 after freight on a new ballenced drive shaft, and after pulling my hair out trying to find the vibration, I checked mounts, set pinion angle, ballenced wheels, checked brake drums, free revved the engine to 3800, you name it, I finally said to myself, I better check the only thing different. The driveshaft I just bought. ITS FREEKING WELDED 3/16 OUT OF ROUND ON THE FRONT YOKE!!! Needless to say I wont be racing at all this weekend. I guess thats what I get when I order a shaft from a dirt track company who specialise in chevy style shafts. When I got the thing, the front yoke felt funny, and had a catch in it. I noticed one of the caps wasnt pushed all the way in. I saw one of the snap rings was over the cap, not in the groove. Chevys are outside snap ring style, so If this guy is use to building these, I can see the possibility of it being wacko. But anyhow, I now know what happened. He probably had the yoke, and the ujoints together, WRONG, then tacked them up, but probably spun up the shaft before welding solid, and since one cap wasnt in correctly he compensated fo this by offsetting his yoke into the tube. If I wouldnt have inspected it, and ran it it wouls have been ok untill the u-joint flew appart. I understand SH*T happens, but I really wanted to run my car this weekend... Oh well..... I can cruise for a bit, I still have heating issues to deal with too. Kasey
[Re: Moparnut426]
#436092
08/14/09 06:33 PM
08/14/09 06:33 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sorry the way things turned out for you this weekend. I wish you lived closer as I have several shafts laying around. Post the length you need and maybe someone can help out.
[Re: Moparnut426]
#436094
08/14/09 07:36 PM
08/14/09 07:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
they did a good job balancing the driveshaft after building it i would put it thru their front window
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: rowin4]
#436101
08/18/09 09:23 AM
08/18/09 09:23 AM
Moparnut426
Is it the drive shaft or the trans main out put shaft? u-joint? Hate to see you trashing somebody's product if it's not the problem. I had two out put shafts bent on two different transmissions. Could be that I drop the clutch at to low of rpm's
Its the shaft fore sure... I measured run out on the tube, and the yoke its self out of the trans, there is nothing at the slip yoke, and the tube is very obvious. You dont need to measure it, too see the wobble. I didnt think I was thrashing them too bad, I know crap happens, I just wouldnt racomend them right now. I see Dennys has a shaft for the same money, and I have seen MANY of them on the drag strip.
Kasey
