Re: Demons got "VIBRATIONS"
[Re: Moparnut426]
#436090
08/14/09 03:37 PM
08/14/09 03:37 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Well, I set my pinion angle 4* down from where it was, and I checked the ballance on the rear wheels, They were off by 2+ oz each. Still vibrates like crazy, I dont feel safe trying to make a maiden voyage down the strip with nast bad vibrations under power at high speeds, so Im just gonna trailer my car to Kearney to check out the cool Old scool cars there, and enjoy a stress free weekend.
Im starting to think I might have something in the tranny causing greef and racket, but I wont dig into that till I pull the engine for the stroker.
Thanks guys for all the sugestions, and help.
Kasey
[Re: Moparnut426]
#436091
08/14/09 05:36 PM
08/14/09 05:36 PM
Moparnut426
OK, now Im just PIZZED beyond belief... I just spent over 350 bucks, 370 after freight on a new ballenced drive shaft, and after pulling my hair out trying to find the vibration, I checked mounts, set pinion angle, ballenced wheels, checked brake drums, free revved the engine to 3800, you name it, I finally said to myself, I better check the only thing different. The driveshaft I just bought. ITS FREEKING WELDED 3/16 OUT OF ROUND ON THE FRONT YOKE!!! Needless to say I wont be racing at all this weekend. I guess thats what I get when I order a shaft from a dirt track company who specialise in chevy style shafts. When I got the thing, the front yoke felt funny, and had a catch in it. I noticed one of the caps wasnt pushed all the way in. I saw one of the snap rings was over the cap, not in the groove. Chevys are outside snap ring style, so If this guy is use to building these, I can see the possibility of it being wacko. But anyhow, I now know what happened. He probably had the yoke, and the ujoints together, WRONG, then tacked them up, but probably spun up the shaft before welding solid, and since one cap wasnt in correctly he compensated fo this by offsetting his yoke into the tube. If I wouldnt have inspected it, and ran it it wouls have been ok untill the u-joint flew appart. I understand SH*T happens, but I really wanted to run my car this weekend... Oh well..... I can cruise for a bit, I still have heating issues to deal with too. Kasey
[Re: Moparnut426]
#436092
08/14/09 06:33 PM
08/14/09 06:33 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sorry the way things turned out for you this weekend. I wish you lived closer as I have several shafts laying around. Post the length you need and maybe someone can help out.
[Re: Moparnut426]
#436094
08/14/09 07:36 PM
08/14/09 07:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
they did a good job balancing the driveshaft after building it i would put it thru their front window
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: rowin4]
#436101
08/18/09 09:23 AM
08/18/09 09:23 AM
Moparnut426
Is it the drive shaft or the trans main out put shaft? u-joint? Hate to see you trashing somebody's product if it's not the problem. I had two out put shafts bent on two different transmissions. Could be that I drop the clutch at to low of rpm's
Its the shaft fore sure... I measured run out on the tube, and the yoke its self out of the trans, there is nothing at the slip yoke, and the tube is very obvious. You dont need to measure it, too see the wobble. I didnt think I was thrashing them too bad, I know crap happens, I just wouldnt racomend them right now. I see Dennys has a shaft for the same money, and I have seen MANY of them on the drag strip.
Kasey
