1969 Dodge Charger ALT Gauge #435573
08/12/09 01:58 PM
08/12/09 01:58 PM
Anonymous OP
Anonymous OP
I've got all my cluster issues worked out except one. When the car is running the ALT gauge is pulling to the NEG. side like its not chargeing. When I put the meter on the battery it shows to be around 14.50-14.60 with the car running. I thought that was correct. Do I have a bad gauge?
Re: 1969 Dodge Charger ALT Gauge #435574
08/12/09 02:09 PM
08/12/09 02:09 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Do you have the red and black wires hooked up correctly on the back of the ammeter? Are they reversed?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 1969 Dodge Charger ALT Gauge #435575
08/12/09 02:11 PM
08/12/09 02:11 PM
Anonymous OP
Anonymous OP
Yes they are correct I've doubled and tripple checked this.
Re: 1969 Dodge Charger ALT Gauge #435576
08/12/09 02:20 PM
08/12/09 02:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Swap them.I dont know why anyone would run the amp gauge anyway.They are the weak link in the wiring.Rocky
Chrysler Firepower
Re: 1969 Dodge Charger ALT Gauge [Re: therocks] #435577
08/12/09 02:31 PM
08/12/09 02:31 PM
Anonymous OP
Anonymous OP
I agree but they complete the circuit. How would do away with it? You did mean swap the gauges not the wires right? I may sound stupid but Mopar electrical systems confuse the living hell out of me.
Re: 1969 Dodge Charger ALT Gauge #435578
08/12/09 04:58 PM
08/12/09 04:58 PM
Andrewh Offline
Andrewh  Offline
you could swap the wires around and see what it does.
But most people bypass it.
Just take one of the wires and put it on the other pole so both are on the same side.
Or just join the 2 or 3 wires together in a connector.
Re: 1969 Dodge Charger ALT Gauge [Re: Andrewh] #435579
08/12/09 06:20 PM
08/12/09 06:20 PM
Anonymous OP
Anonymous OP
Doing this doesn't really solve the problem, because usually the ammeter is NOT the problem. Usually it's the wiring, the connections in the firewall connector and other places. If you are going to bypass it at all, you need to run a large ga bypass under the hood "before" it gets to the ammeter
The way to tell if your ammeter is correct is to simply turn on the headlights with the engine off. It should go to the left. If not, reverse the two wires on the rear.
Re: 1969 Dodge Charger ALT Gauge #435580
08/12/09 06:40 PM
08/12/09 06:40 PM
yes if the wires are reversed, switch them to resolve the problem at hand then the ammeter bypass can be decided on at a later date
Re: 1969 Dodge Charger ALT Gauge #435581
08/12/09 07:45 PM
08/12/09 07:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Why - not that much differnt than any other one. They all have circuits, fuses, relays, switches, etc.
Re: 1969 Dodge Charger ALT Gauge [Re: MoparforLife] #435582
08/12/09 09:02 PM
08/12/09 09:02 PM
Anonymous OP
Anonymous OP
What can I say I cut my teeth on GM cars with internal voltage reg. and no extra field wires.
Re: 1969 Dodge Charger ALT Gauge #435583
08/13/09 03:07 AM
08/13/09 03:07 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Did you make any wiring modifications?
If you connected the alternator output directly to the battery it would cause the problems you are seeing.
Re: 1969 Dodge Charger ALT Gauge [Re: 451Mopar] #435584
08/13/09 11:38 PM
08/13/09 11:38 PM
Anonymous OP
Anonymous OP
I just found that my 1969 Dodge Charger engine harness which I ordered from Year One is actualley a 1970 engine harness which changes several things including the voltage reg. I just compared wiring diagrams of the 69 & 70 chargers and noticed that it appears that the red and black Alt gauge wires on a 70 model are oppisite of the 69. For instance if your looking at the gauge face on the 69 the red wire goes to the positve side and black goes to the Neg. side. From what I can tell on a 70 the red is going to the neg. and the black to the pos. Does anyone know this for sure. On my cluster the Pos. post has RED stamped into the metal beside it.
Re: 1969 Dodge Charger ALT Gauge #435585
08/13/09 11:43 PM
08/13/09 11:43 PM
I am just finishing rewiring my 65 dart from head to toe & I got(& still am a bit) confused looking at the factory wiring diagrams(ie the bulkhead) whether it was showing the back or the front side. Luckily I am driving an identical 65 dart GT so I can go eyeball things but it was still a moderately major ordeal. Do double check as in fact you may be good as is.
Re: 1969 Dodge Charger ALT Gauge #435586
08/14/09 12:54 AM
08/14/09 12:54 AM
Anonymous OP
Anonymous OP
No idea. I didn't even use to worry about it. I'd just "clip lead" the ammeter terminals when reinstalling the cluster, try the lights, and if wrong, I'd reverse 'em. No big deal
