Bell housing I.D. #435469
08/12/09 10:33 AM
08/12/09 10:33 AM
Caldwell, Idaho
67R/T4speeder Offline OP
Caldwell, Idaho
Looked in the archives section but cannot find this one listed . Its aluminum look`s like small block . Cast # 2892513 Thanks
Re: Bell housing I.D. [Re: 67R/T4speeder] #435470
08/12/09 10:43 AM
08/12/09 10:43 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
72-74 B 400-440, 70-71 B,C,A383,426,440 (just read the casting number you posted)
Post the casting date and the installation year can be narrowed down.
Re: Bell housing I.D. [Re: 67R/T4speeder] #435471
08/12/09 10:44 AM
08/12/09 10:44 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
This is what I found..
Re: Bell housing I.D. [Re: 67R/T4speeder] #435472
08/12/09 10:57 AM
08/12/09 10:57 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I believe small block has top center bolt...Easy way to tell 'em apart
Re: Bell housing I.D. [Re: 67R/T4speeder] #435473
08/12/09 10:59 AM
08/12/09 10:59 AM
Caldwell, Idaho
Caldwell, Idaho
05102 found below Cast# is that the date ?
Re: Bell housing I.D. [Re: 67R/T4speeder] #435474
08/12/09 11:06 AM
08/12/09 11:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, I don't think so, take a closeup pic of the area covered by the trans and I'll spot it for you
Re: Bell housing I.D. [Re: ScottSmith_Harms] #435475
08/12/09 11:17 AM
08/12/09 11:17 AM
Caldwell, Idaho
Caldwell, Idaho
Cheap camera phone wont take close-ups . I did see a 69 on there , and I just looked at another bell housing out of a `71 Hemi Cuda I have apart over here and it has the same Cast# w/ 70 . Guess I should have compared the two first .
Re: Bell housing I.D. [Re: 67R/T4speeder] #435476
08/12/09 11:29 AM
08/12/09 11:29 AM
Caldwell, Idaho
Caldwell, Idaho
Heres Hemi car one
Re: Bell housing I.D. [Re: 67R/T4speeder] #435477
08/13/09 08:32 AM
08/13/09 08:32 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You didn't ask about date coding and what it came out of just the application so does it really matter ?
