I run a 440+6 in the car with the original 22" Radiator. I'd like to get more efficient cooling. Are there better (3 or 4 core) radiators out there that look OEM? Would having a local Rad shop re-core the original and increase capacity help? The engine doesn't appear to overheat, per se, but my gut feeling is it's running too hot, and I only have the factory gauges that tell me everything is "fine" but I don't really trust them. I get a lot of gurgling and bubbling even after short runs with the thing after I shut it down and have tried to burp the system with no change.
