Considering gear swap, Updated Quest: 3:73's or 3:91's?
#435267
08/11/09 09:34 PM
08/11/09 09:34 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Running a 496, auto, 166k conv., 3:23's, 275/60 MT drags(28" tall) in 3800lb 69 Bee; Considering jumping to either 3:73's or 3:91's.
Anyone made a similar swap and how much rpm increase at cruise speed(70mph) should I expect compared to my current 3:23 setup.
Any first hand experience or recommendations regarding the 3:73 or 3:91?
Ran a best of 11.98 @ 113, any overall ET improvements to expect or just better 60ft times?
The cruise rpms at say 70mph is my main concern.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Considering gear swap, how much rpm increase at cruise?
[Re: Hoof Hearted]
#435268
08/11/09 09:47 PM
08/11/09 09:47 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
At 70 it will rev about 3500-3800 rpm with 3.91 gear. somebody had the perfect gear-rpm-tire calc. site on here once.
I know 3.91's will rev over 3500 rpm cause my buddy's 68 runner has a 4 speed with a 28" tire and 3.91's and they are running some good rpm's just at 60.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#435269
08/11/09 10:12 PM
08/11/09 10:12 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
With 3.91 gears and a 28 inch tire you will cruise about 3350 at 70 mph with 3.71 gears 3200 will give you 70 cruise. The mechanical advantage of a 3.91 over a 3.23 will get you .35 to .4 tenths maybe a smig more. the 3.71s will gain .25 to .3 in my experience. better 60 foot's always give better quarters and the mechanical gear advantage is there the whole quarter.
[Re: BDS871Cuda]
#435271
08/11/09 10:48 PM
08/11/09 10:48 PM
My Charger with 383, 4-speed, and 3.91s runs 3200 rpm @ 60 mph.
#435272
08/12/09 01:16 AM
08/12/09 01:16 AM
BDS871Cuda
Are you at or above 3500 rpm at 70 mph?
I think his tach might be off a couple hundred rpm. When I ride in it, the factory tach seems to read high.
[Re: BDS871Cuda]
#435273
08/12/09 01:35 AM
08/12/09 01:35 AM
RapidRobert
what ever your actual rpm is, going from 3.23 to 3.91 will up it 21% (3.73-15.4%) if the converter slippage is the same
[Re: RapidRobert]
#435275
08/12/09 09:18 PM
08/12/09 09:18 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
With a 26 inch tire you can about double the first 2 numbers of the tach reading for the MPH.
[Re: MoparforLife]
#435276
08/13/09 06:59 AM
08/13/09 06:59 AM
Posts: 4,713 Florida
BDW
[Re: Hoof Hearted]
#435277
08/13/09 01:56 PM
08/13/09 01:56 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
well, that's easier that you think
if 3.91 is 21% increase on ratio, then the RPM increase will be about the same
3.73 is 15.5% increasing on ratio from 3.23
[Re: Hoof Hearted]
#435279
08/13/09 07:34 PM
08/13/09 07:34 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
What is your 60 ft now?
[Re: BSB67]
#435280
08/16/09 10:21 PM
08/16/09 10:21 PM
Hoof Hearted
S.E. Conn
Quote: "What is your 60 ft now?"
Reading the 2 year old faded time slip from LVD:
reaction time: 0.0186
60 ft: 1.792
1/8th mile: 7.668
Note the awkward stance of the rear tires when she launches, she lifts up, and goes, no slipping, no spinning; Mopar XHD rear springs, adustable pinion snubber, stock 440 t-bars, stock cheapo shocks all around...oh yeah, running a simple Eddy 800cfm mounted on a TM7.
11.98 @ 113.52 (w/3:23's, 275/60/15-28"T) M/T Drag Radials
Anyone got an educated recommendation for gears? Leaning towards 3:73's or 3:91's, no steeper than that as the car is driven on the street alot.
[Re: Hoof Hearted]
#435281
08/16/09 11:50 PM
08/16/09 11:50 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
60 ft: 1.792
1/8th mile: 7.668
Hey what is your engine combo? Compression,headers,cam and what heads do you have? Just trying to get an idea of what numbers to expect with that stroker combo.
[Re: Blakcharger440]
#435282
08/17/09 12:52 AM
08/17/09 12:52 AM
Hoof Hearted
S.E. Conn
496/, .30 over, Moly rings,(440source guts), Lunati .533int./.552exh.-284/292adv.-242/252 dur.@.050 Hydr. cam 105 ctr., Mopar alum. wedge heads(unported), TM7, Eddy 800(worked over), 1 7/8 Hooker super comps, 3" collector, 3" duals, w/"H" pipe and Flowmasters. 727,manual reverse V.body, $210 Mopar "Economy Hi-Stall" 166k converter... Enough info? Very simple cheapo setup. Has terrific street manners and runs high 11's with an overwieght italian with his right foot planted firmly to the floor.(I hear 100lbs wieght loss will net me 1/10 on 1320...) Long term goal is to be able to run consistant mid 11's w/ no juice. Now, gear ratio advice please.
[Re: Hoof Hearted]
#435284
08/17/09 09:05 PM
08/17/09 09:05 PM
BSB67
Prospect, PA
60 ft: 1.792
1/8th mile: 7.668
If the only change you will consider is a gear change, and you want the most et improvement, go with the 3.91.
However, your 60' isnt bad for a street car. You might get it down to a 1.70 with the 3.91, and that will drop your et .15 to .2. Add a good 9.5" converter and drop to maybe a 1.60 sixty ft., and an additional .15 to .2 off the et.
The 113.5 mph seems a little low to me. The gear change won't effect this as the mph is a function of horsepower. If the tune is good, I would check that you have good fuel pressure through the traps, borrow and try a 850 DP Holley and maybe try some carb spacers too. I think it could run 116 or 117, and would drop the et by .25 to .35, and you can keep the 3.23s and $ in your pocket
