Challenger vin rivets #435259
08/11/09 09:31 PM
08/11/09 09:31 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I have a 70 Challenger that I am replacing the dash pad with an Ultimate Rides pad. Along with the trimming I had to do for a/c vents etc. I now have another problem. The replacement pad has some padding where the vin plate attaches. I tried to rivet the plate on but the rivets are not long enough to grab the metal frame without pushing downon the plate and bending it. I don't want to take a chance of damaging the plate. Seems I have seen someone advertise a longer vin rivet that may solve the problem. Any thoughts?
Gerry
Re: Challenger vin rivets [Re: GKMOPAR] #435260
08/12/09 04:12 AM
08/12/09 04:12 AM
None
71rm23 Offline
71rm23  Offline
None
Try ecs auto, a member here. He has the kit
Re: Challenger vin rivets [Re: GKMOPAR] #435261
08/12/09 06:02 AM
08/12/09 06:02 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
What ever way you go with the rivits, if you try to attach the tag with all that foam under it you'll bend the snot out of it when you pull the rivit tight enough to break the nail. I've lived that dream, after straightening out the tag I ended up using emblem adhesive to hold the tag and original rivit heads to the pad.
Re: Challenger vin rivets [Re: 71rm23] #435262
08/12/09 09:51 AM
08/12/09 09:51 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Does anyone have contact info for ecs auto? I thought I would not be the only one who has had this issue. Thanks for the input.
Re: Challenger vin rivets [Re: GKMOPAR] #435263
08/12/09 10:21 AM
08/12/09 10:21 AM
cataclysm80 Offline
cataclysm80  Offline
Can you slit the vinyl under where the plate goes and get some of that foam out of there?
Tav
Re: Challenger vin rivets [Re: cataclysm80] #435264
08/12/09 12:27 PM
08/12/09 12:27 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Tav
I have done this in the past with success.
Re: Challenger vin rivets [Re: N9671X2] #435265
08/12/09 12:36 PM
08/12/09 12:36 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Funny you mentioned that as I had the same thought this morning. If I can evenly remove some of the foam it may work.
Re: Challenger vin rivets [Re: HEMICUDA] #435266
08/12/09 12:55 PM
08/12/09 12:55 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Mine was not that bad but my Vin is dented down where the rivits go on my just dashes pad.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
