Are the half panels I see on E-bay any good or are they junk! Im doing alittle patch work on what will be a decent daily driver. The lower quarters behind the wheels are bad and a small spot in front of the wheels along with the lip and I just thought maybe the half panels could be cut to make work.
Also. I need the outer trunk floor extentions, are those all about the same as far as quality for the repro's.
What do you guys think?
