Breather Lines to Headers #435238
08/11/09 08:54 PM
08/11/09 08:54 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
Can I do this for a street car or is this strictly for racing only without mufflers? Did I just answer my own question?
Re: Breather Lines to Headers [Re: JohnnyBeGood] #435239
08/11/09 09:16 PM
08/11/09 09:16 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
more of a race thing most mufflers have to much back pressure and will burn out the one way check valves that are used in a evac system then it will pressureize the crank case.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Breather Lines to Headers [Re: dusturbd340W5] #435240
08/11/09 10:17 PM
08/11/09 10:17 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
They will work with 3" exhaust and a high flow muffler like the Dynomax ultra flow welded.
You need a minimum of a PCV and an open breather in the other valve cover street otherwise.
Re: Breather Lines to Headers [Re: dusturbd340W5] #435241
08/11/09 10:29 PM
08/11/09 10:29 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
I installed Pan-Evacs (Crankcase Evacuation Systems) on both my '71 Charger and my '79 Jeep CJ5 w/ Factory AMC 304 V8.
The '71 Charger has 3 1/2-inch dual-exhaust and Dynomax free flowing mufflers, (not all that restrictive) so the Pan-Evac draws a fair vacuum.
The Jeep engine has headers and 3-inch Dual exhaust.
