Preserving blocks,cranks and heads! #435203
08/11/09 08:42 PM
08/11/09 08:42 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
I just purchased a bunch of these and what is the best way to preserve them while in storage from rusting? They have already been cleaned and magged!
Re: Preserving blocks,cranks and heads! [Re: JohnnyBeGood] #435204
08/11/09 08:44 PM
08/11/09 08:44 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
SPRAY 'em with fogging-oil and then bag 'em.
Re: Preserving blocks,cranks and heads! [Re: JohnnyBeGood] #435205
08/11/09 08:45 PM
08/11/09 08:45 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Store them in a dry place with a coat of wheel bearing grease on the machined surfaces.
Re: Preserving blocks,cranks and heads! [Re: Neil] #435206
08/11/09 11:10 PM
08/11/09 11:10 PM
USA
max Offline
super gas
max  Offline
super gas
USA
i have actually had parts still rust using wheel bearing grease and if they didn't rust the grease left some weird looking stains behind when it was wiped off.
lately i have been using plain old WD-40 on parts that i plan on using in the next year or so that seems to work.
another thing i did one time and was told this by a machine shop was to paint the crank journals. the crank had a fresh turn on it and i didn't know when i was going to get around to using it so i painted them and 3 years later i just used some thinner and wiped it off and used the crank.
Re: Preserving blocks,cranks and heads! [Re: max] #435207
08/11/09 11:14 PM
08/11/09 11:14 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I have heard of the paint trick, but haven't tried it myself yet.
I didn't think moisture or humidity could penetrate through wheel bearing grease.
Re: Preserving blocks,cranks and heads! [Re: Neil] #435208
08/11/09 11:32 PM
08/11/09 11:32 PM
USA
max Offline
super gas
max  Offline
super gas
USA
from what i understand it usally has to do with the humidity in the air when the grease is applied. once the grease goes on it traps moisture and if there is any thin spots where air can get through it will start to rust.
the paint trick works really well but can be somewhat of a pain to keep the paint off the areas you don't want it on.
that crank i did stood up in a homemade wooden box near my garage door that had all kinds of moisture around it for 3 years and when i wiped it down it looked like it came right from the machine shop.
Re: Preserving blocks,cranks and heads! [Re: JohnnyBeGood] #435209
08/11/09 11:50 PM
08/11/09 11:50 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Re: Preserving blocks,cranks and heads! [Re: D_C] #435210
08/11/09 11:53 PM
08/11/09 11:53 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Preserving blocks,cranks and heads! [Re: Noblewk] #435211
08/12/09 12:37 AM
08/12/09 12:37 AM
billy mays space bags. add your parts and some dessicant to absorb any left over moisture & draw the air out with your vacuum cleaner suction side. No air no rust
