Re: Project Young Gun: 1971 Super Bee Budget Build
[Re: HemiChallenger]
#43490
02/06/08 09:42 AM
02/06/08 09:42 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Put in heat and AC. You will never regret it
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: 70Coronet500Vert]
#43491
02/14/08 04:20 PM
02/14/08 04:20 PM
Posts: 8,000 Millersville, PA
HemiChallenger
Millersville, PA
Hey guys, just got back from a ski trip in vermont so havent been able to work on the bee obviously. But here is some stuff that got done the last two days... The top of the drivers quarter was pretty well rotted as seen below... So i cut a section out of the sunroof charger donor to patch it, its not the exact piece since its was junk too but it can work with some modification... Then here she is welded in place... Then back to the tail panel rot issue ![](/ubbthreads/images/graemlins/flame.gif) This car is so rusted ![](/ubbthreads/images/graemlins/laugh2.gif) Here is the tail panel extension that we have to use drilled off... Here is a patch for the top of it from the first donor car... Then i drilled this piece apart to fix the right way... I'll finish that piece up next and hopefully lay the whole back end in together before we start welding... ![](/ubbthreads/images/graemlins/beer.gif)
#43492
02/15/08 08:48 AM
02/15/08 08:48 AM
70Coronet500Vert
St Charles MO
How many spot weld bits you gone through to date and how much are they are why aren't they in your budget numbers?
#43493
02/15/08 08:52 AM
02/15/08 08:52 AM
Posts: 4,872 connecticut
pnypwr
connecticut
because most people dont figure in cost of materials till the end! those blair bits are reiliant if you keep the rpm low they last and last I dont have that kind of patiance so i tend to go thru them!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
#43494
02/15/08 09:01 AM
02/15/08 09:01 AM
Challenger 1
Cincinnati, Ohio
I wonder if he's using reg drill bits? If so that would be cheap on the budget. ![](/ubbthreads/images/graemlins/thumbs.gif)
#43495
02/15/08 10:23 AM
02/15/08 10:23 AM
HemiChallenger
Millersville, PA
Those numbers are not going to factored until the end. I will add a material cost for bits(5 packs as of now) and 6 cans on primer right now. I want to wait until all the hole drilling is dont and all the primer usage is done. Pretty much once the sheetmetal work is complete. ![](/ubbthreads/images/graemlins/thumbs.gif)
#43496
02/15/08 01:00 PM
02/15/08 01:00 PM
Posts: 2,766 Appleton, Wisconsin
rtmike
Appleton, Wisconsin
This is one of my favorite posts ever! You guys are doing a great job on that car, and 71 Superbees are awesome cars to boot. Keep up the good work. It goes to show you that you do not need $250,000 to build a cool car!
Its not primer its perma gray.
[Re: QuickBpBp]
#43501
02/15/08 11:55 PM
02/15/08 11:55 PM
HemiChallenger
Millersville, PA
Keep drillin
imagine if you had the drill welds in the Bee too instead of just peeling them apart you'd be up around 3600 drilled ![](/ubbthreads/images/graemlins/laugh2.gif) I saw that car and I knew it was rough but not that rough... You guys are learning alot with that one...
Funny you say that, the whole floor, trunk floor and back end was pretty much chisseled off lol. Wait until you see the post later tonight of what i just had to salvage to make the car work, i feel like this was a hand built car having to fab up all these pieces lol. Stay tuned ![](/ubbthreads/images/graemlins/laugh2.gif)
#43502
02/16/08 02:17 AM
02/16/08 02:17 AM
HemiChallenger
Millersville, PA
Did some more work today, mostly fabrication and fixing of some of the more seriously rusted out areas. Here is the two extension pieces that go from the trunk extensions to the frame crossmember. As you can see the one is okay but the other is junk, sadly this is the best one from all three cars, so it had to be used. I cut the upper lip and then the piece in half for the most part... Here is what will be the new side... Cut out the relief cut and the angled area at top... Here are the two tabs i made... Welded up the made up piece... The one new tab welded on... The finished product... Also did the tail panel extension, top piece welded on... Bottom piece fabricated and then welded on... ![](/ubbthreads/images/graemlins/beer.gif)
#43503
02/16/08 12:05 PM
02/16/08 12:05 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
You know...seeing your work continues to keep me going on my project without fear or concern of what lay ahead. Keep it up. ![](/ubbthreads/images/graemlins/thumbs.gif)
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
#43507
02/21/08 01:15 AM
02/21/08 01:15 AM
Posts: 149 Clovis,NM
Dartman318
Clovis,NM
I have been silently following this thread. I was brought home from the hospital in this 74' Charger. ![](http://i40.photobucket.com/albums/e237/kpgsx/MVC-008E-2.jpg) Keeping her shaded by a Mesquite Tree....I like A-bodies. Need any little misc. stuff?
