TTI Exhaust Test #434948
08/11/09 06:23 PM
08/11/09 06:23 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
This past w/e I was able to do a back to back test: Open headers vs TTI X-Pipe and Dynomax Ultra-FLo mufflers.
With the weather being in the upper 80's-90's I hoped I could pick up a tenth by uncapping my car.
I haven't ran it uncapped in 3yrs and thought this would help. First run uncapped 10.64 at 127mph, second run added 14" header extensions 10.61 at 127mph, third run put the X-Pipe and mufflers back on approx 60lbs 10.62 at 127 again. I was actually faster at the 1/8 with the exhaust, 102 vs 101 uncapped. The runs were within 2hrs and the DA changed less than 150ft from start to finish.
Re: TTI Exhaust Test [Re: nss guy] #434949
08/11/09 06:38 PM
08/11/09 06:38 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Thats pretty surprising to me, especially since you had actually pulled the mufflers and pipes from the car, would have thought 60 lbs would have showed up as an adder even if the open headers didn't, pretty suprising, either the engine breathes better with the exhaust on or your tuned for it one.
Re: TTI Exhaust Test [Re: nss guy] #434950
08/11/09 06:44 PM
08/11/09 06:44 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Good info to know.You and Myron(Locomotion stocker) have had very similar results.How "loud" are the Ultra Flo's??
Nautilus Racing-
Re: TTI Exhaust Test [Re: Chris2581] #434951
08/11/09 06:45 PM
08/11/09 06:45 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
They're not loud at all. Until you get on it!!
codfish
Re: TTI Exhaust Test [Re: nss guy] #434952
08/11/09 07:26 PM
08/11/09 07:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you do any jetting for the best in each case
Re: TTI Exhaust Test [Re: MR_P_BODY] #434953
08/11/09 08:07 PM
08/11/09 08:07 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
No Jetting changes, believe it or not it's not very sensitive to jetting changes, I run it slightly on the rich side.
Re: TTI Exhaust Test [Re: wyoming] #434954
08/11/09 08:11 PM
08/11/09 08:11 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
I found out that after switching from an "H" Pipe to the X-pipe weight did not slow the car down. 100lbs was always a sure tenth with the H-pipe, switched to the X and 100lbs was maybe .03... I had to learn a whole new way to adjust the ET. The X-pipe does add more torque in my opinion.
Re: TTI Exhaust Test [Re: nss guy] #434955
08/12/09 06:09 PM
08/12/09 06:09 PM
Indiana
N
nssracer1 Offline
nssracer1  Offline
N
Indiana
How big a shot of NOS did you use on those passes?
Re: TTI Exhaust Test [Re: nssracer1] #434956
08/12/09 08:20 PM
08/12/09 08:20 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Re: TTI Exhaust Test [Re: nssracer1] #434957
08/12/09 08:43 PM
08/12/09 08:43 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
The pills were stamped 50hp, and the bottle wasn't heated.
OOPS!!!!!!!
You tricked me into that answer
Re: TTI Exhaust Test [Re: nss guy] #434958
08/12/09 08:50 PM
08/12/09 08:50 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
On a serious note,
In my experience the TTI X-Pipe actually made more power (torque) than open headers. I was actually hoping I could count on picking up .05+ by running uncapped. That is not the case, the X-pipe really helps.
Re: TTI Exhaust Test [Re: nss guy] #434959
08/12/09 08:52 PM
08/12/09 08:52 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
On a serious note,
Jim, on a serious note why are you running 10.60's when I know the car will run 10.30's sandbagging
Russ
Re: TTI Exhaust Test [Re: max_maniac] #434960
08/12/09 09:10 PM
08/12/09 09:10 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
Russ,
The car will run 10.30's in 2000 or less DA on Radials. My M/T Radials lasted 52 passes!! I bought bias slicks Friday and they are a sure tenth plus slower. I thought I'd cover the 10.50 index by pulling the exhaust, not the case. Just wanted to pass the info.
Re: TTI Exhaust Test [Re: nss guy] #434961
08/12/09 09:42 PM
08/12/09 09:42 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Russ,
Gotcha ---- I have MT's on mine and I should have stayed with the Hoosier radials like I had on the 64. I had good luck with those and ran them for a couple of years before they gave out. However that was on a lighter car and it was only a 9" tire and not a 10.5 so that could have helped with the longevity.
Russ
Re: TTI Exhaust Test [Re: max_maniac] #434962
08/12/09 10:45 PM
08/12/09 10:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats good info to know. Thanks for passing that info along. I run the Ultra-Flows but I use an H-pipe and not the X-pipe so I dont know how well mine works. I may pick up a tad uncapped. My Ultra-Flows are not real loud unless I am on it hard. I can and do listen to my radio while driving and right now I only have the dash speaker. Is that a 3" system ? Ron
Re: TTI Exhaust Test [Re: max_maniac] #434963
08/13/09 05:41 PM
08/13/09 05:41 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
Russ,
My M/T radials were 9" wide also, I was really disappointed in the longevity.
383 Man,
I have the 3" system
Re: TTI Exhaust Test [Re: nss guy] #434964
08/13/09 05:52 PM
08/13/09 05:52 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
My brothers car has a 3" TTI X-pipe exhaust feeding Borla Race mufflers and 2 1/2" tailpipes over the axles to factory appearing tips. I have been itchin to remove the exhaust to see if it benefits at all. I will be monitoring the wide band oxygen sensor and make the necessary adjustments so the air/fuel ratios are the same for comparison. It would be nice to know if the car didnt benefit from open exhaust because its a real pain in the booty to take the exhaust off at the track.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: TTI Exhaust Test [Re: PUNK] #434965
08/13/09 06:17 PM
08/13/09 06:17 PM
Texas
TexasStroker Offline
mopar addict
mopar addict
Texas
Thanks for the info
Founder, Amarillo Area Mopars & Lone Star Mopars Amarillo Area Mopars Lone Star Mopars Chryslers in the Canyon: All Mopar Event!
Re: TTI Exhaust Test [Re: TexasStroker] #434966
08/13/09 09:21 PM
08/13/09 09:21 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
is there any gain running 3" from headers thru x pipe to 2.5" muffs and then out 2.5" pipes vs running the 2.5" the whole way from the headers?
I have the 2.5 dynamax aar style muffs (inlet/outlet both sides) and the 2.5" aar trumpets.
they dont make the muffs or the trumpetyailpipes in 3"
Re: TTI Exhaust Test [Re: aarcuda] #434967
08/14/09 07:14 AM
08/14/09 07:14 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Do anyone know if there is a manufacturer out there that sells a 3 1/2" x-pipe and if so,by any chance no the weight #'s on it?I run the 3 1/2"bullets and would love to quiet it down some but not add to much weight. Use to run the Flow masters 2 chambers (love the sound)hate the restriction.Thax.
