Powerglide in small block E body? #434769
08/11/09 12:31 PM
08/11/09 12:31 PM
IN
Irun5snd8th Offline OP
IN
Anyone dropped a powerglide into an E-body behind a small block? If so what kind of problems did you run into? Clearance etc.?
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434770
08/11/09 01:24 PM
08/11/09 01:24 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
They never brought enough fuel with them to the track
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434771
08/11/09 01:53 PM
08/11/09 01:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I havent BUT what is the weight of the car... I would
believe it would really hurt the 60' and maybe
down track if its in a heavy car. I have a glide
for my BB thats going into my car but it wont be
in it for some time yet
Re: Powerglide in small block E body? [Re: MR_P_BODY] #434772
08/11/09 02:15 PM
08/11/09 02:15 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
There is a guy I race with around here with a very pretty '72 Challenger that weighs around 2800lbs. Big block car on a small tire that runs 6.40's in the 1/8th. He didn't mention any fitment problems. I think he picked up a little bit but he was under tired and was spinning with the 727.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434773
08/11/09 02:31 PM
08/11/09 02:31 PM
ggddemon Offline
ggddemon  Offline
I have a Howards alum. glide with a J.W ultrabell setup on it for the last three years. no issues at all. I could forsee a tight fit with the ultrabell if you retain your stock trans tunnel and a blanket setup.
I'm just in the process of finishing a full rollered 904 to put into my car{70-cuda /32.5x16x15/4.86/59* w-9 / Rons toilet setup and now has 5.67 gear and does 6.04@113 with a 1.32 60' My sons runs a 48* w-9 all steel car{ 72 cuda} with his 904 for the last 4 years and never any problems he does 6.20@111 in the 660' If I had to start from scratch it would definately be a 904 and leave the glide to the bow tie babies
dave
Re: Powerglide in small block E body? [Re: ggddemon] #434774
08/11/09 02:57 PM
08/11/09 02:57 PM
, PA
sleepyhead416 Offline
, PA
904
Re: Powerglide in small block E body? [Re: sleepyhead416] #434775
08/11/09 03:26 PM
08/11/09 03:26 PM
IN
IN
Lets leave the quick ET stuff out of this one. I have several reasons I am thinking about this. I have been 1.28 60fts with my ride as it sits with a 904 in it. So obviously it would 60 ft slower in my car. Is the ultrabell the way to go on this deal or is there a better method for attaching?
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434776
08/11/09 03:40 PM
08/11/09 03:40 PM
SD800 Offline
SD800  Offline
Go with the ultrabell, buy the wheel and adapter also. I'm sure you know the benifits of the glide.
You'll have plenty of time to sleep when your dead, let's go
Re: Powerglide in small block E body? [Re: SD800] #434777
08/11/09 10:17 PM
08/11/09 10:17 PM
IN
IN
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434778
08/11/09 10:31 PM
08/11/09 10:31 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I don't think that the ultra bell is any larger than the 727 bell and we know that it will fit. If I were buying new I would consider the ATI case/bell. I do run JW bells, but had problems with their "wheel". This was with 850Hp though. Run a Reactor alum wheel now.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Powerglide in small block E body? [Re: Dan Brewer] #434779
08/11/09 11:47 PM
08/11/09 11:47 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Buy the aftermarket case if you can swing it. No shield necessary. Could not fit shield in Cuda tunnel. Also if using PPP shifter, shift arm or floor needs modified. Ultrabell fits fine w/ BB. Mount sits 4 or 5 inches forward of crossmember in car.
Good Luck
Gotta deal on PG stuff if anyone interested.
Re: Powerglide in small block E body? [Re: TheBlackCar] #434780
08/11/09 11:53 PM
08/11/09 11:53 PM
ky
68roadrunner Offline
ky
Good Luck
what kind of pg parts?
Re: Powerglide in small block E body? [Re: 68roadrunner] #434781
08/12/09 12:03 AM
08/12/09 12:03 AM
IN
IN
This is all great info. Didn't realize that ATI had a bell. PM me about those parts.
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434782
08/12/09 10:08 AM
08/12/09 10:08 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I'm running Ultra-bell, JW Ultra-case, the Mizier billet flexplate and JW adapter. No clearance issues at all, plenty of room in the tunnel.
Not sure why it would matter if it was a small or big block, if anything the SB should have more room.
Just had to modify the rear tranny mount that it wasn't any big deal.
It does leave a little softer but if your bracket racing it doesn't matter, I'd just assume loose a little ET for the consistency and since it leaves a little softer you'll have less problems at marginal tracks.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Powerglide in small block E body? [Re: WadeMetzinger] #434783
08/12/09 11:07 AM
08/12/09 11:07 AM
Out West
408strokerdart Offline
Out West
Do yourself a favor and go with the Reid case if you go glide. I will probably do this next year in my a-body.
Re: Powerglide in small block E body? [Re: 408strokerdart] #434784
08/12/09 11:58 AM
08/12/09 11:58 AM
IN
IN
What is a Reid case? I know Deadenbear makes one but that puppy is expensive.
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434785
08/12/09 12:18 PM
08/12/09 12:18 PM
IN
IN
Nevermind! The Reid looks identical to the Dedenbear so must be a partner/rebrand thing. Wade, obviously I have a driveshaft swap to do as well but what else do I need that hasn't been mentioned? I am pretty sure I can get a different plate for my Turbo Action shifter to work with the glide.
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434786
08/12/09 12:28 PM
08/12/09 12:28 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: Powerglide in small block E body? [Re: SB449VALIANT] #434787
08/12/09 12:31 PM
08/12/09 12:31 PM
Mcallen, TX
Mcallen, TX
noter
Re: Powerglide in small block E body? [Re: SB449VALIANT] #434788
08/12/09 12:34 PM
08/12/09 12:34 PM
Mcallen, TX
Mcallen, TX
last
