Powerglide in small block E body?
#434769
08/11/09 12:31 PM
08/11/09 12:31 PM
Posts: 2,864 IN
Irun5snd8th
IN
Anyone dropped a powerglide into an E-body behind a small block? If so what kind of problems did you run into? Clearance etc.?
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
Re: Powerglide in small block E body?
[Re: Irun5snd8th]
#434771
08/11/09 01:53 PM
08/11/09 01:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I havent BUT what is the weight of the car... I would believe it would really hurt the 60' and maybe down track if its in a heavy car. I have a glide for my BB thats going into my car but it wont be in it for some time yet
[Re: MR_P_BODY]
#434772
08/11/09 02:15 PM
08/11/09 02:15 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
There is a guy I race with around here with a very pretty '72 Challenger that weighs around 2800lbs. Big block car on a small tire that runs 6.40's in the 1/8th. He didn't mention any fitment problems. I think he picked up a little bit but he was under tired and was spinning with the 727.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Irun5snd8th]
#434773
08/11/09 02:31 PM
08/11/09 02:31 PM
ggddemon
I have a Howards alum. glide with a J.W ultrabell setup on it for the last three years. no issues at all. I could forsee a tight fit with the ultrabell if you retain your stock trans tunnel and a blanket setup. I'm just in the process of finishing a full rollered 904 to put into my car{70-cuda /32.5x16x15/4.86/59* w-9 / Rons toilet setup and now has 5.67 gear and does 6.04@113 with a 1.32 60' My sons runs a 48* w-9 all steel car{ 72 cuda} with his 904 for the last 4 years and never any problems he does 6.20@111 in the 660' If I had to start from scratch it would definately be a 904 and leave the glide to the bow tie babies dave
[Re: sleepyhead416]
#434775
08/11/09 03:26 PM
08/11/09 03:26 PM
Posts: 2,864 IN
Irun5snd8th
IN
Lets leave the quick ET stuff out of this one. I have several reasons I am thinking about this. I have been 1.28 60fts with my ride as it sits with a 904 in it. So obviously it would 60 ft slower in my car. Is the ultrabell the way to go on this deal or is there a better method for attaching?
[Re: Irun5snd8th]
#434776
08/11/09 03:40 PM
08/11/09 03:40 PM
Posts: 388 Michigan
SD800
Go with the ultrabell, buy the wheel and adapter also. I'm sure you know the benifits of the glide.
You'll have plenty of time to sleep when your dead, let's go
[Re: TheBlackCar]
#434780
08/11/09 11:53 PM
08/11/09 11:53 PM
Posts: 877 ky
68roadrunner
ky
Buy the aftermarket case if you can swing it. No shield necessary. Could not fit shield in Cuda tunnel. Also if using PPP shifter, shift arm or floor needs modified. Ultrabell fits fine w/ BB. Mount sits 4 or 5 inches forward of crossmember in car.
Good Luck
Gotta deal on PG stuff if anyone interested.
what kind of pg parts?
[Re: 68roadrunner]
#434781
08/12/09 12:03 AM
08/12/09 12:03 AM
Posts: 2,864 IN
Irun5snd8th
IN
This is all great info. Didn't realize that ATI had a bell. PM me about those parts.
[Re: Irun5snd8th]
#434782
08/12/09 10:08 AM
08/12/09 10:08 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I'm running Ultra-bell, JW Ultra-case, the Mizier billet flexplate and JW adapter. No clearance issues at all, plenty of room in the tunnel.
Not sure why it would matter if it was a small or big block, if anything the SB should have more room.
Just had to modify the rear tranny mount that it wasn't any big deal.
It does leave a little softer but if your bracket racing it doesn't matter, I'd just assume loose a little ET for the consistency and since it leaves a little softer you'll have less problems at marginal tracks.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: 408strokerdart]
#434784
08/12/09 11:58 AM
08/12/09 11:58 AM
Posts: 2,864 IN
Irun5snd8th
IN
What is a Reid case? I know Deadenbear makes one but that puppy is expensive.
[Re: Irun5snd8th]
#434785
08/12/09 12:18 PM
08/12/09 12:18 PM
Posts: 2,864 IN
Irun5snd8th
IN
Nevermind! The Reid looks identical to the Dedenbear so must be a partner/rebrand thing. Wade, obviously I have a driveshaft swap to do as well but what else do I need that hasn't been mentioned? I am pretty sure I can get a different plate for my Turbo Action shifter to work with the glide.
[Re: Irun5snd8th]
#434790
08/12/09 03:08 PM
08/12/09 03:08 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Nothing wrong with using stock glide cases, even stock 1.76 gear sets. You wont have any strength issue's. A few parts in those tranny's are need to be replaced, but after this you will have a strong transmission. I have personally put pass after pass on a stock glide with stock 1.76 gears. Built by yours truely, turning 1.07 60ft times A few things that need changed. -300M input shaft -aftermarket clutch hubs that holds more clutches -billet servo piston-Kevlar bands -1.76 planets -aftermarket valve body -deep pan -pump mods -case mods If your not chasing E/T in a class, lots of people don't care to give up a little E/T for consistency. E/T loss could be substantial, maybe a tenth or more. Then again it might not be near that much with the right converter. I want to add that converter choice is a little more crucial in a glide, so ask around and get some recommendations.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#434791
08/12/09 03:26 PM
08/12/09 03:26 PM
Posts: 2,864 IN
Irun5snd8th
IN
If I do this my converter will be an ATI and I will be sending an ATI core to them and tell them my specs to have one built.
[Re: RACEEWING]
#434793
08/12/09 03:52 PM
08/12/09 03:52 PM
Posts: 2,864 IN
Irun5snd8th
IN
Do you know what kit or adapter that Jerry was using? One thing that I am taking into consideration is using the Coan adapter kit and using an actual Powerglide without a Bell. This for the simple fact that there are always spare glides laying around in my buddies shops and trailers for that matter.
[Re: chryco]
#434797
08/12/09 11:11 PM
08/12/09 11:11 PM
Posts: 766 Ohio
Dan Brewer
Ohio
I don't think that the ultra bell is any larger than the 727 bell and we know that it will fit. If I were buying new I would consider the ATI case/bell. I do run JW bells, but had problems with their "wheel". This was with 850Hp though. Run a Reactor alum wheel now.
I will be running a JW Glide with "The Wheel " what kind of problems will I be encountering ?
I had one loose a section of ring gear and broke the ultra bell, ripped through the headers and poked a hole in the oil pan. Diaper on the engine saved the car. I took it out and it was cracked at every weld.
[Re: Dan Brewer]
#434798
08/13/09 02:24 PM
08/13/09 02:24 PM
Posts: 2,864 IN
Irun5snd8th
IN
Any more info? This has been a great thread for learning.
