Re: Repairing late model headliners, best practices?
[Re: Paul]
#434751
08/11/09 02:02 PM
08/11/09 02:02 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
what happens is the foam under the fabric deteriorates, usually due to a combination of heat and humidity. I've tried many things, the only way to fix it once and for all is to replace the foam backed fabric. any attempts to re-glue the existing fabric has only lasted about a month max for me.
if you go to the nearest Jo-Ann's fabric, they have the headliner fabric for ~ $11/yd. smaller stores have grey and black, the super stores have grey, black, blue, red, and tan. they also have some lock-tite spray contact cement for ~$12 that worked good for me and is comparable to the heat resistant 3M super 90 spray adhesive (the stuff that usually runs $15-20 at the parts store). before you buy it, sign up to receive Jo-anns ads in the mail. they come out every 2 weeks or so, and they have a 40% off any regular priced item coupons, which drops the price of the fabric to under $7, and the adhesive to under $8.
once you get the headliner out, peel the fabric off, and gently use a wire brush to get the stuck on foam off. I wiped the one on my 5th ave down with some laquer thinner before applying the adhesive and recovering.
[Re: Paul]
#434754
08/12/09 07:11 AM
08/12/09 07:11 AM
patrick
Grand Haven, MI
on my 5th ave and a friend's '89 pontiac grand am it's almost like a pressed fiberglass board w/o resin, a little springy and some flex to it but can be kinked.
you could try peeling back the bad part, scrubbing off the deteriorated foam, and spraying some of the aforementioned adhesive in there, but don't expect that fix to last too long or look too good.
it took me a few weeks of evenings to do my 5th ave, but ALL trim panels are fabric covered on these cars (A,B,C pillar, rear window surround, upper rear door sail panel, and the headliner). my friend removed, cleaned, re-covered, and reinstalled the headliner in his grand prix on a saturday morning (3-4 hours tops)
[Re: 360view]
#434756
08/12/09 08:59 AM
08/12/09 08:59 AM
Posts: 4,764 near Port Huron, MI
Paul
near Port Huron, MI
PS: Got milky spots on your Ram paint, especially on the hood and roof? These are cracks allowing water beneath the clear coat. Best temporary fix is to clean milky area, dry carefully, set in sun for more drying, then spray with WD-40 to displace the water in the cracks. This improves appearance for 3 to 7 days depending on weather.
Yep, got those and the peeling/missing clear coat as well. I've been collecting rust free and new body panels for mine. A complete repaint is in the plans.
