E85 Timing ?????? #434637
08/11/09 11:13 AM
08/11/09 11:13 AM
S.L . MI
clutch Offline OP
clutch  Offline OP
S.L . MI
What are you guys running for timing with E85 compared to gas???
Re: E85 Timing ?????? [Re: clutch] #434638
08/11/09 06:45 PM
08/11/09 06:45 PM
S.L . MI
clutch Offline OP
clutch  Offline OP
S.L . MI
Anyone
Re: E85 Timing ?????? [Re: clutch] #434639
08/11/09 07:04 PM
08/11/09 07:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm still working on my timing... I'm up 2 degrees
but it looks like it still wants more
Re: E85 Timing ?????? [Re: MR_P_BODY] #434640
08/11/09 07:18 PM
08/11/09 07:18 PM
S.L . MI
clutch Offline OP
clutch  Offline OP
S.L . MI
2 over racing gas??
Re: E85 Timing ?????? [Re: clutch] #434641
08/11/09 07:23 PM
08/11/09 07:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
2 over racing gas??
Yes I was running 112 and changed to E-85 and so far
I went up 2 degrees but like I said it wants more, I'm
thinking I will be about 6 degrees above the 34* I
used for race gas... but I still need to test more
Re: E85 Timing ?????? [Re: MR_P_BODY] #434642
08/11/09 08:57 PM
08/11/09 08:57 PM
NC
440Jim Offline
440Jim  Offline
NC
I haven't done a good back to back series of ignition timing tests... yet. I have been running the same 34 that I ran with race gas (flat top pistons, quench). On gas, my engine ran the same at 34 and 36, but slowed down at 38.
When I started with E-85, I did my first pass or two at 30 for safety, but then went to 34 and it was quicker.
Re: E85 Timing ?????? [Re: clutch] #434643
08/12/09 04:39 AM
08/12/09 04:39 AM
sweden
street_dart Offline
street_dart  Offline
sweden
33 on e85 and 36 on race gas.
I test this in engine dyno.
I was up on 38 on e85 and ther the power starts dropping fast. Backed down and it was the same power and trq on 36 and 33 so I run 33.
The VP motorsport 109 like the 36 better and made 10Hp more on 36 compered to 33.
This was on my motor i dont know what your motor like.
Dodge Dart-67 Dodge Custom Royal Lancer-55 Dodge Dakota 4.7 -05
