Air/Fuel Ratios from bottom to top of RPM curve? #434617
08/11/09 11:09 AM
08/11/09 11:09 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
For you guys that have either dyno data or use the on-board wideband O2 meters, do you find that your "tuned" WOT air/fuel ratios from bottom to top of RPM curve are fairly close, or do they tend to swing one way or the other?
I spoke w/ Dwayne Porter about seeing this on the dyno data for my engine where we tested a few different carbs. In this case, my Claw had a lean bias (not a "spike, a more gradual change) in the mid-range of a 3500-7000 RPM pull (i.e. ran richer near the bottom and peak RPMs). His "dyno mule" Holley 850 annular carb showed much more consistent a/f ratios across the pull, as did an 8896 HP 4500 we tested.
We know this can be the result of a combination of things... emulsion settings, booster signal, air bleeds. However, pinpointing the reason for going lean in that manner isn't so cut-n-dry. It just "is" at this point.
EDIT: I'll throw another related question on here... do you "want" to see a different air/fuel ratio at peak torque than at peak HP?
So... what have you guys seen from your own tests?
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: BradH] #434618
08/11/09 01:01 PM
08/11/09 01:01 PM
I like to see it flat, that makes it more controllable by using the main jets . Try adjusting the size of the idle and high speed bleeds to control the AFR from bottom to top of the RPM band On the HP Domintor you may have to adjust the size of the kill bleeds in the metering blocks
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: Cab_Burge] #434619
08/11/09 01:20 PM
08/11/09 01:20 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
from last weekend, i saw an immediate rich then a lean spike then a gradual leaning out near the the top end (5500 to 6200)
im still playing though
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434620
08/11/09 03:41 PM
08/11/09 03:41 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Smaller MAB's should help flatten the curve.
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: BradH] #434621
08/12/09 11:04 AM
08/12/09 11:04 AM
BradH Offline OP
BradH  Offline OP
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434622
08/12/09 11:35 AM
08/12/09 11:35 AM
Is the immediate rich the accelerator pumps? Leaning out at the upper RPM needle and seat size?
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: Cab_Burge] #434623
08/12/09 01:25 PM
08/12/09 01:25 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
thats what Im thinking. I get a dump of gas and go rich. then it runs out and I get a lean spike. Why it creeps back a little lean at the top of 2nd gear and then again in 3rd, i have no idea.
Im going to try 2 things next week end. take out my 34 squirter and try a 28 and see if that mellows the initial rich and spreads the squirt longer to prevent the lean.
I also have a brown 500cc pump cam I want to try.
For the lean creep in second, maybe its the outboards fully opening??? I have plain springs in there now. I would think the outboards would be wide open at 6000 in first and stay that way thru 2nd and 3rd. I want to try some others.
I wish I knew when the outboards were opening/fully open. I need to figure out how to rig a tps to the outboards
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434624
08/12/09 02:28 PM
08/12/09 02:28 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
the lean condition on top end may be high speed air bleeds. try two sizes smaller. that should richen it up a bit. do this with an air/fuel gauge so you can see whats going on.
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: mopar dave] #434625
08/12/09 03:18 PM
08/12/09 03:18 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
how do you change them on a car with pressed in bleeds? Do i have to try and drill the old ones our and screw in the screw in type? I'd hate to do that on my original carbs. Is there a way to change something on the Promax jet plate that would accomplish the same thing?
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434626
08/12/09 08:27 PM
08/12/09 08:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve heard of guys putting epoxy in em and drillin em to the desired size AFTER measuring em w/a pin vise. Or, you can use a fine wire in the existing ones and see if it improves and if so, modify the carb for screw in bleeds.
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: BradH] #434627
08/12/09 09:14 PM
08/12/09 09:14 PM
AndyF Online content
AndyF  Online Content
To the best of my knowledge you want a flat AF curve but heck if I know. You might try posting this question over at Speedtalk or just do a search over there first. It is a topic that comes up a lot over there with the EMC guys.
Another suggestion is to call the tech line at BLP (Bo Laws) Those guys are pretty darn smart carb guys and they'll talk. The guys at Braswell are also darn smart but they usually don't talk, or at least, they don't talk to me!
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434628
08/12/09 09:50 PM
08/12/09 09:50 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Try some fine wires in the MABs to see if that pulls the curve richer. I take some fine strands from a little piece of 16 or 18 guage wire. You can mike them, they usually come out about to .008"-.012". Stick one or two in each MAB and record a pass. The wire test will tell you if the MABs need to be smaller and maybe even by how much. And it's quick and easy. I do it all the time on both air and fuel orifices.
Master, again and still
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: Thumperdart] #434629
08/12/09 10:56 PM
08/12/09 10:56 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
ya, the wire method... duh, i knew that. i used that years ago on my idle bleeds (used bent over paperclips).
cool, more tests to follow!!
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434630
08/12/09 11:55 PM
08/12/09 11:55 PM
Is this a six pak set up? If so let me know, I have several sets, one of them is really good I may be able to help
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434631
08/13/09 07:34 AM
08/13/09 07:34 AM
Virginia
JimG Offline
JimG  Offline
Virginia
AAR:
Another way besides the wires is to drill out the original air bleeds (after measuring them and recording the sizes), tap the channel (usually 8-32) and buy some brass set screws from an industrial supplier like McMaster-Carr. 3/16" length works well for IABs and MABs. Drill the brass set screw to the desired diameter and screw it in.
Wires work, but it can be kludgey. If the wire isn't inserted perpendicular to the orifice you're trying to reduce, its effective footprint becomes larger than the measured diameter of the wire. The upside, of corse, is that you don't risk messing something up when you drill and tap your carb.
In your case, yes the smaller MABs will richen it at the top end and delay the start of the mains at low airflow (thereby possibly making a lean spot off-idle). Juggling a larger jet and smaller MAB might be the ticket; only testing will tell.
Aren't you running aftermarket metering blocks? If so, how many emulsion bleeds and what size are they?
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: JimG] #434632
08/13/09 07:50 AM
08/13/09 07:50 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
AAR:
i have the promax metering block and the jet plates for the outboards. i dont think the jet plates have provisions for adjustment other than they accept holley jets. the center carbs metering block has the stock emulsion bleeds in their now.
I would imagine i'd want to be messing with the outboard MABs but I really dont want to go and drill and tap them. Im not really a numbers guy but on this, date coded 0500 original 6bbls carbs, I dont want to make a permanent change by drilling them.
Is there a way to change the center carbs metering block oriface to get this done? of maybe the jet plate oriface could be modified??
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434633
08/13/09 11:41 AM
08/13/09 11:41 AM
Virginia
JimG Offline
JimG  Offline
Virginia
Why was I thinking you were running a 4-barrel Holley or a clone?
What would you consider stock e-bleeds? 2 e-bleeds in the 2nd and 4th hole (assuming you have 5) at .026" - .028" each? Some newer Holleys have 3 e-bleeds per side, so "stock" could be construed at least 2 ways!
I don't blame you.
Short answer: not really. Long answer: you "might" see some success by making the e-bleeds smaller if they're much larger than .028", and if you now have 3, reduce it to 2 and be sure you emulate the "old" Holley configuration in both size and location. I've seen this change fatten the AFR at higher RPM cruise, and I've seen it not make any difference at all.
Cab Burge's suggestion (needle & seat) is a good one and very easy to check.
And just for the record, your posted log was running on the inboard carb only at cruise, right? Since you don't have a TPS, it's hard to tell.
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: JimG] #434634
08/13/09 11:58 AM
08/13/09 11:58 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i would imagine the cruise is only running on the center carb but without a tps, i am not sure. I am going to try the ol bread bag tie on the diaphragm rod trick this week and that will give me a redneck TPS.
as for the emulsion bleeds in the center metering block, i seem to recal they are .031 and there are 3 of the. the other 2 or 3 are plugged
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: aarcuda] #434635
08/13/09 12:09 PM
08/13/09 12:09 PM
Virginia
JimG Offline
JimG  Offline
Virginia
First things first: be sure the outboards are out of the picture when the problem occurs. Next, try what Cab Burge said.
3 e-bleeds at .031" makes me suspicious, but do the other stuff first. I think you're on the right track.
Re: Air/Fuel Ratios from bottom to top of RPM curve? [Re: Cab_Burge] #434636
08/13/09 01:38 PM
08/13/09 01:38 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
I guess its obvious now but yes, these are somehat modified 340 six pack carbs. i have the promax base plates and jet plates for the outers, and the promax metering block for the center carb.
the choke plate has been removed, the center jets are 64's and the others are 84's. running the plain springs in the outboards diags 50cc pump with he white cam. squirter is a 34 (i drilled out a 32 I had).
