loose control arm bushing fix? #434411
08/10/09 10:32 PM
08/10/09 10:32 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Anyone have a quick fix for loose upper control arm
bushings? Mine are not as tight as I'd like them to
be. Would adding the oem sleeve on the back be good
enough?
Re: loose control arm bushing fix? [Re: Dart 340] #434412
08/11/09 01:51 AM
08/11/09 01:51 AM
IMGTX Offline
IMGTX  Offline
If the bushings are turning in the arm the arm is junk IMHO.
The only fix for an arm like that is to tack weld the bushing into the arm but I would replace it.
Tack welding a bushing melts the rubber and it will fail prematurely and your back to square 1.
Re: loose control arm bushing fix? [Re: IMGTX] #434413
08/11/09 09:54 AM
08/11/09 09:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: loose control arm bushing fix? [Re: JohnRR] #434414
08/11/09 09:54 PM
08/11/09 09:54 PM
SW CO
HemiSportFury Offline
SW CO
Replacing the arm is best, but it's pretty easy to remove the rubber bushing, tack weld the metal housing and reinstall the bushing.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
