HOLLEY 850 DP STOCK JETTING????? #434385
08/10/09 10:17 PM
08/10/09 10:17 PM
Anonymous OP
Anonymous OP
Not sure what the list # is on a borrowed 850 dp,from Mr. P-Body,what are the majority of them jetted at? 80-88,76-84???? My GTX runs cleaner jetted at 78-86,but runs cooler at 80-90. Also,seems faster on the top end. Haven't had it to the track as of yet this season! Sooon! RandyB
Re: HOLLEY 850 DP STOCK JETTING????? #434386
08/10/09 10:24 PM
08/10/09 10:24 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
If it is a 4 corner idle 850 it should have .081 on the primary and .080 on the secondary. I have 3 of them.
Re: HOLLEY 850 DP STOCK JETTING????? #434387
08/10/09 10:27 PM
08/10/09 10:27 PM
Hemiroid Offline
Hemiroid  Offline
WE need to have a "X" shootout!! Unfortunately, you'll only be allowed 7 plug wires for this race.
Re: HOLLEY 850 DP STOCK JETTING????? [Re: mercman1] #434388
08/10/09 10:30 PM
08/10/09 10:30 PM
Anonymous OP
Anonymous OP
Merc,it's a 4-corner idle model! So,you're saying 81 jet primary and 80 secondary,I'm assuming both PV's are installed! I never run a secondary PV,just the primary,when street driving. At the track,I square-jet all four corners. RandyB
Re: HOLLEY 850 DP STOCK JETTING????? [Re: Hemiroid] #434389
08/10/09 10:35 PM
08/10/09 10:35 PM
Anonymous OP
Anonymous OP
7 plug wires??? I'll even throw in 32* total timing,and shift at 5500 rpm!
Re: HOLLEY 850 DP STOCK JETTING????? #434390
08/10/09 11:15 PM
08/10/09 11:15 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Oooops my bad primary is .080 and secondary is .078. Im getting old and memory is fogging. Get me the list # and Ill double check my Holley ref guide.PS here is a pic of my X...10.84 at 122.1.49 sixty ft. 493, pump gas, eddy heads, 3.73 gear. 3960lbs w/driver
Re: HOLLEY 850 DP STOCK JETTING????? [Re: mercman1] #434391
08/11/09 09:53 PM
08/11/09 09:53 PM
Anonymous OP
Anonymous OP
Robert, SWEEEET cars! Is the Challenger a T/A? I'll try to get the list # tomorrow. Hopefully, Raff(Mr. P-Body)didn't grind them off when he made some modifications to it! RandyB
Re: HOLLEY 850 DP STOCK JETTING????? #434392
08/11/09 10:20 PM
08/11/09 10:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy I have no idea if those numbers are there or
not... I did that carb about 9 or 10 years ago... I
cant even remember yesterday.... LOL
Re: HOLLEY 850 DP STOCK JETTING????? [Re: MR_P_BODY] #434393
08/11/09 11:03 PM
08/11/09 11:03 PM
Anonymous OP
Anonymous OP
So Raff,you trying to tell me that senility's startin' to set in? I realize you're gettin' up there in years! On the carb... I went from 80/90 w/front pv to 74/84 and it really runs clean,and stronger than I thought it would! Had it runnin' in the pole barn,and the fumes were minimal! I still need to get it over to Jake and get it all dialed in correctly! RandyB
Re: HOLLEY 850 DP STOCK JETTING????? #434394
08/11/09 11:42 PM
08/11/09 11:42 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Is one better off running both pv's on a street/strip car?
Re: HOLLEY 850 DP STOCK JETTING????? [Re: Blown61] #434395
08/12/09 01:52 AM
08/12/09 01:52 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
How you been Randy? I run your basic Holley 850 DP also. I dont remember the stock jetting but I have 78's and 86's in it now on my 906 headed MP.557 cammed 440. I jetted the secondary from 84's to 86's and picked up about 1 mph so I left it like that. The car burns fairly clean and never fouls plugs at all putting around town. I put over 100 miles on the 63 this past weekend and it runs great. I would think your engine may take more jetting then mine as your eng is a bit stronger then my 440. I know you sure have it running good. Ron
Re: HOLLEY 850 DP STOCK JETTING????? #434396
08/12/09 08:33 AM
08/12/09 08:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy I was doing some looking around and seen this
it might help you(and this list number sounds familiar)
4781 850 (F)80,(R)80 6.5,6.5 4150
4781-1 850 (F)80,(R)80 6.5,6.5 4150
4781-2 850 (F)80,(R)80 6.5,6.5 4150
4781-3 850 (F)80,(R)78 6.5,6.5 4150
4781-4 850 (F)80,(R)78 6.5,6.5 4150
4781-5 850 (F)80,(R)78 6.5,6.5 4150
Adjust the secondary accordingly for no PV
Re: HOLLEY 850 DP STOCK JETTING????? [Re: MR_P_BODY] #434397
08/12/09 12:16 PM
08/12/09 12:16 PM
Anonymous OP
Anonymous OP
Thanks,Ron! The X is running pretty strong! Mike,looks like the baseline jet is a 80. That was my guess. The Demon 850 was also a 80 primary. See ya at the Cutter later! Randy
