Re: OIL Restrictors for INDY Block
[Re: Ari440]
#433901
08/10/09 05:46 PM
08/10/09 05:46 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Hello Billy I drilled and taped the Y block going into the block, for the holley jet as described above. This saved me from needing to do both fittings in both heads. I ran a .075 holley jet, which then split off to each side feeding the rocker arms. This setup worked perfect. I ran the Jesel system, and made my own spray bar oiling lines from 3/16 brake line. This setup seen season after season of runs, and abuse, whats nice about the Jesel system, is even running spring loads approaching 800LBS open. They never moved. I checked lash about three times a season. And it never needed corrected or adjusted. IMO if the move, something isnt right or wearing. I cant recall what size the fitting was in the Indy Maxx block though. I know the factory blocks have two, one 1/4 and the other 3/8 NPT... Looks to be ONE 3/8 NPT oil galley port, can you confirm?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Ari440]
#433902
08/10/09 06:12 PM
08/10/09 06:12 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
BINGO!! there it is.that goes in the block then the hose goes over that.atleast thats what i was tryin to sorta say kinda.
[Re: bonefish]
#433903
08/10/09 06:32 PM
08/10/09 06:32 PM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
one of my friends told me that they are using a .065 hole in the restrictor and said they are still getting too much oil.. what sizes are you guys using ?? ..Thanks guys for the great info and pics.. i will take care of that so as my car comes back from chassis shop.. Headers are being built.. *************** BONEFISH to answer your question here is what the 572ci Indy is going in..63 Dart that i have been building for the past 1 1/2 years..
[Re: Ari440]
#433906
08/11/09 08:14 AM
08/11/09 08:14 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
Is this the fitting that goes in the head or what.. do I do the head side or the block side.
