Re: Weather ratios to predicet E.T. How do you do it?
[Re: Quicktree]
#433851
08/10/09 06:39 PM
08/10/09 06:39 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Get a weather station.... There are a few out there,,,,relatively inexpensive,,,eg TAG,,,,etc. I have used mine for the past 2 seasons,,,and it has helped alot,,, I dont change my car AT ALL,,,,ie,,,i dial according to the weather............ I plug in the temp, barom, humidty,,etc,,,,and it calculates the DA,,etc,,,, I record everything in a log book,,,, Over the past 1-2 years,,,,i can tell exactly what the car will do,,,based on the change in weather,,,,only variable is the track,,etc. It is very helpful for eliminations as well,,,,,after a few time trials,,,,i can log the runs,,,and then pick a "dial" time,,,for eliminations,,,,as the night goes on,,and the weather changes,,,,,it is very accurate,,,at least with my car.... As far as tuning,,,it's also helpful,,,eg,,,if my car is "way off",,,and i cant explain it by the weather changes,,,i know i have a problem somewhere,,,and can start looking....... good luck,
[Re: dustyhof]
#433852
08/10/09 07:17 PM
08/10/09 07:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've been using a Tag weather station for years... I dont know what they want to know the corrected DA, I want to know what the engine will see and with the tag I can get within a few thousands but you only dial to the hundredth
[Re: dustyhof]
#433854
08/10/09 07:37 PM
08/10/09 07:37 PM
69CHARGERMD
KENTUCKY
Wow,,,,$1,000 and up ? I am just a weekend,,bracket racer,,,few times a month,,,that got tired of losing in the first round,,,b/c i couldnt run the number,,,or know where to dial the car,,,and was just guessing.... I think a TAG,,etc,,would be OK,,, I put a link to the system i bought,,,same one as 65Racer (Davey Boyd) on the board,,,who is a great racer,,, http://www.ifamilysoftware.com/I think the TAG might be a bit easier to use.....
[Re: dustyhof]
#433855
08/10/09 07:40 PM
08/10/09 07:40 PM
MR_P_BODY
The TAG weather stations are that accurate? Looks like they are about $430 from Jegs. A couple of my buddies have the trailer mounted units with the Crew Chief Pro program and the whole setup is like $1500! Would this be a waste of a $1000?
I have the Crew Chief also... but I dont use that anymore... I just plug my ET into the Tag(after I save it at the starting line/ staging lanes) then it does all the work for me. Once you establish a data base(just a few runs) it gets more and more accurate, plus it has 4 data bases in it... I use them for different tracks and 1/8 mile stuff
[Re: MR_P_BODY]
#433856
08/10/09 07:45 PM
08/10/09 07:45 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Would I be able to keep each car seperat with the Tag?
I'm looking for a new weather station myself.
[Re: MR_P_BODY]
#433857
08/10/09 07:50 PM
08/10/09 07:50 PM
Posts: 502 Huron, South Dakota, United St...
dustyhof
So this little guy does everthing that the Crew Chief program does? This is a run log book also?
[Re: WILD BILL]
#433858
08/10/09 07:52 PM
08/10/09 07:52 PM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
Yes you keep up with four cars or four tracks. I have one and like it a lot . My problem is that I don't believe it and dial something different , it's usually closer than I am.
[Re: dustyhof]
#433861
08/10/09 08:29 PM
08/10/09 08:29 PM
WILD BILL
BROOK PARK, OH
If we ever add a fifth car I'm in trouble though
[Re: dustyhof]
#433862
08/10/09 08:42 PM
08/10/09 08:42 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Walk around the pits at a big event and look at everyone's weather station set ups. Some use hand helds, some rival NOAA. They all read amazingly different, some close some 500 feet dif, within 5min. The TAG unit is popular, what we use.
The little old lady from Pasadena is back!
[Re: Lil Wedge]
#433864
08/10/09 10:42 PM
08/10/09 10:42 PM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I have a tag that I will sell.
Not that it is not a good unit, I don't trust the ET predictor. Sometimes it was dead on and sometimes it wasn't.
I just use it to record the weather in my logbook.
Why does divorce cost so much?
Because it is worth it!!!!!
