Shifter cable length #433666
08/10/09 11:51 AM
08/10/09 11:51 AM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
I'm replacing the shifter cable in BB Duster with 727. The existing cable is a 5' but it seems short, as it makes a near 90* turn into the tranny bracket. The headers are off right now so I'm not sure if a 6' would fit in there. What length do you BB Duster guys use?
Re: Shifter cable length [Re: Mofopar] #433667
08/10/09 12:09 PM
08/10/09 12:09 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I'm running a 6ft with pro-part headers...
Re: Shifter cable length [Re: 70dusterjohn] #433668
08/10/09 01:18 PM
08/10/09 01:18 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Are you using front exit or rear exit? In a rear exit PPP, BB, Demon with a 727 - I'm using the 5'.
Re: Shifter cable length [Re: Lil Demon] #433669
08/10/09 01:21 PM
08/10/09 01:21 PM
Deerfield, Ohio
Deerfield, Ohio
front exit.. but I had to move the seat back so I also moved the shifter and raised it off the floor. So that may be where I needed the longer cable. The seat now sits in the foot area for the rear seat..
Re: Shifter cable length [Re: Mofopar] #433670
08/10/09 01:44 PM
08/10/09 01:44 PM
United States
STLDuster Offline
STLDuster  Offline
United States
I am running a Tubro Action Cheatah Shifter, I was able to use the cable supplied with the shifter. I believe it is 5' long.
That is my '74 Duster with a 440/727 and schumacher headers.
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Shifter cable length [Re: Lil Demon] #433671
08/10/09 04:56 PM
08/10/09 04:56 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Exits at front on passenger side of tunnel. What's PPP by the way?
I'll get some pics,,,
Re: Shifter cable length [Re: STLDuster] #433672
08/10/09 05:18 PM
08/10/09 05:18 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Will this work with reverse valve body?
Re: Shifter cable length [Re: Mofopar] #433673
08/10/09 05:22 PM
08/10/09 05:22 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Here's a pic of the cable on the bracket. Looks too tight for my liking.
Re: Shifter cable length [Re: Mofopar] #433674
08/10/09 11:56 PM
08/10/09 11:56 PM
United States
STLDuster Offline
STLDuster  Offline
United States
IF I am not mistaken Turbo Action makes a shifter specifically for the reverse manual valve bodies. As far as I know it is the same shifter frame and cable as mine. So it SHOULD work out but... every car is different.
