Serpentine belt systems...???? any suggestions as to #433477
08/10/09 07:02 AM
08/10/09 07:02 AM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
the manufactures? I know they get crazy with the prices.
Re: Serpentine belt systems...???? any suggestions as to [Re: 62BT409] #433478
08/10/09 08:12 AM
08/10/09 08:12 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Motor Body Accessories
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Serpentine belt systems...???? any suggestions as to [Re: 62BT409] #433479
08/10/09 08:12 AM
08/10/09 08:12 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
big block or small block? i've got a big block kit i put together. we are switching over to billet brackets and getting away from the cast brackets.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Serpentine belt systems...???? any suggestions as to [Re: 62BT409] #433480
08/10/09 09:45 AM
08/10/09 09:45 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
For a big block take a look at 440Source's stuff. I bought a set and its VERY nice. Not polished to a high gloss but a very nice finish. Unlike the other systems on the market, theire does not have any mounting bracket or tensioner systems so this GREATLY reduces the cost. What you end up with is a system that adjusts the good old fashined way but uses a serpentine belt.
Re: Serpentine belt systems...???? any suggestions as to [Re: Stanton] #433481
08/10/09 02:37 PM
08/10/09 02:37 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
not to sounds arrogant, but whats the poin in using a serpentine belt system that has to be adjusted manually? the best part of the system is the spring loaded tensioner that keep the belt taught at high RPm, cruise rpm, and various shock loads from turning on the accessories.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Serpentine belt systems...???? any suggestions as to [Re: Jerry] #433482
08/10/09 04:25 PM
08/10/09 04:25 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Accessories ??? We don' need no steenkeen accessories !!!
Actually I thought the best part was the (approx.) $ 150.00 price tag !!!
I change the oil in the sucker, I can sure as hell check and adjust belt tension !!!!!!!!!!
Re: Serpentine belt systems...???? any suggestions as to [Re: Stanton] #433483
08/10/09 04:31 PM
08/10/09 04:31 PM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
I thought the same as you about "evilspirit"'s post. But the price tag is about $2200.00 to $2600.00 for a 426 Hemi.......OUCCHH with the A/C compressor
