what should i do t buld a 450 hp 904 #433410
08/10/09 12:24 AM
08/10/09 12:24 AM
littlestown pa
dustpan man Offline OP
littlestown pa
i went trought 3 904s so far and im about to buld one for a 400+hp and 400+ftlbs
Re: what should i do t buld a 450 hp 904 [Re: dustpan man] #433411
08/10/09 01:39 AM
08/10/09 01:39 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
what hp did the other 3 have going to them?
Re: what should i do t buld a 450 hp 904 [Re: 70blackfish] #433412
08/10/09 02:26 AM
08/10/09 02:26 AM
littlestown pa
littlestown pa
well one was stock then i bought a tci 450hp one blue and fixed seconed blue it out and 3rd slipin now soo im wornderin how to keep seconed in
Re: what should i do t buld a 450 hp 904 [Re: dustpan man] #433413
08/10/09 02:36 AM
08/10/09 02:36 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
What does the car weigh ? ...what rear-end gearing? .. these are important factors.
Re: what should i do t buld a 450 hp 904 [Re: dOrk !] #433414
08/10/09 08:38 PM
08/10/09 08:38 PM
littlestown pa
littlestown pa
3100 with a full tank of gas and it has 323s in the rear
Re: what should i do t buld a 450 hp 904 [Re: dustpan man] #433415
08/10/09 08:49 PM
08/10/09 08:49 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
are you sure the throttle pressure linkage is adjusted correctly?
Tony
70 AARCuda Vitamin C
Re: what should i do t buld a 450 hp 904 [Re: 70AARcuda] #433416
08/11/09 03:52 AM
08/11/09 03:52 AM
Well the first was stock and the second was a t.c.i...if you have one properly built they will last,i run one in my 3180 lb '70 duster with either my 520 h.p. 416 stroker or my 400 h.p. 360,and it has held up for 3 seasons of abuse at the track with really no issues...
Re: what should i do t buld a 450 hp 904 #433417
08/11/09 10:37 AM
08/11/09 10:37 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have a Cope trans and it works perfectly. I have a 450 HP small block. Not an HP guess, engine dyno results.
Re: what should i do t buld a 450 hp 904 [Re: babarracuda] #433418
08/11/09 11:17 AM
08/11/09 11:17 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I am over 400 hp with a stock 904 with only a manual vb in a 3100 lb car. Been fine for 2 years of racing. 4.30 rear and a 4k stall.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: what should i do t buld a 450 hp 904 [Re: StandOnIt] #433419
08/12/09 01:07 AM
08/12/09 01:07 AM
St. John's Newfoundland
440newport Online content
440newport  Online Content
did those 904's have manual valve bodies? If not, did you have the kickdown linkage hooked up?
Re: what should i do t buld a 450 hp 904 [Re: 440newport] #433420
08/12/09 03:13 AM
08/12/09 03:13 AM
littlestown pa
littlestown pa
[Edited by Moparts - Family Friendly Site - Keep it clean] down is good ok im gonna buld one with stock clutchis kevelar bands and a hard hitin shift kit a 3.8 leaver type f fuid i dont got money for a deep pan
if it dont hold up im goin 727
Re: what should i do t buld a 450 hp 904 [Re: dustpan man] #433421
08/12/09 03:58 AM
08/12/09 03:58 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Me thimks you are probably hard on the ole 904 trans. .... and the 3.23 gear is not helping either.
I would suggest a 727 and be done with it.
