PAINTING MY TRUCK(ADVISE FOR A FIRST-TIMER) #433189
08/09/09 10:26 PM
08/09/09 10:26 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Painting my truck in a couple days do you guys have any advise?
I Am using Dupli-color
-I got the primer and color
Re: PAINTING MY TRUCK(ADVISE FOR A FIRST-TIMER) [Re: midnite360] #433190
08/10/09 07:09 PM
08/10/09 07:09 PM
East Liverpool, OH
b body dreams Offline
East Liverpool, OH
make sure everything is clean. Blow out all the door jambs, hood jambs...ect. Blow the engine compartment out thoroughly. You want as little dust as possible to wind up in the new paint. Take your time and dont rush things. the extra time spent will be well worth it.
Re: PAINTING MY TRUCK(ADVISE FOR A FIRST-TIMER) [Re: b body dreams] #433191
08/11/09 07:40 AM
08/11/09 07:40 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
And make sure the area you're painting in is clean and dust free with no misquitos.
Re: PAINTING MY TRUCK(ADVISE FOR A FIRST-TIMER) [Re: midnite360] #433192
08/11/09 08:09 AM
08/11/09 08:09 AM
go to lowes or home depot. and get some naptha or mek, and use it to wipr down the aera your painting. also if you are useing the paint from autozone,advance auto or pep-boys,be carefull not to run it, had a bad experince with it. i would use a real paint from napa car quest or any bodo supply store. what kind of gun are you useing?
Re: PAINTING MY TRUCK(ADVISE FOR A FIRST-TIMER) #433193
08/11/09 10:40 AM
08/11/09 10:40 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Duplicolor? Spray cans?
The best advise I can give you is to work as clean as possible, as others have mentioned.
Also, do a test panel. It may seem like a pain to get an old fender and do it first, but you will probably learn something just doing that old fender that will make the final paint job better.
Be very carefull, follow the instructions. Lots of paints and chemicals these days can mess you up permanently.
Re: PAINTING MY TRUCK(ADVISE FOR A FIRST-TIMER) [Re: RodStRace] #433194
08/11/09 05:57 PM
08/11/09 05:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Ask her to pick the color.
Re: PAINTING MY TRUCK(ADVISE FOR A FIRST-TIMER) [Re: RodStRace] #433195
08/11/09 08:35 PM
08/11/09 08:35 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Duplicolor makes a premixed laquer primer/paint/clear system they sell off the shelf at places like autozone. I researched up on this stuff a bit and the concensus is it's not a good paint, some guys who used it said even a gas spill would take it off! No hardener/activator/catalyst to mix in with the paint so I could see why. I would honestly return that stuff if this is what you bought and go to your local auto body supply and buy the real stuff.
Re: PAINTING MY TRUCK(ADVISE FOR A FIRST-TIMER) [Re: DaytonaTurbo] #433196
08/11/09 09:24 PM
08/11/09 09:24 PM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
dont waste all that time prepping and then spray junk on, waste of time and money, better off keeping your truck white until you got more money
