Need 440 head tips #43204
07/14/07 04:24 AM
07/14/07 04:24 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
The 440 block has all the right machine work done; decked, bored with plates, line bore checked.
Lightweight J & E pistons and pins, stock rods w/ ARP bolts, steel crank, all components balanced.
Racer Brown 543/509 hydraulic cam.
Non ported 906 heads w/ big valves and triple springs, original rockers. Melling hi flow, 8 qt oil pan.
Complete MSD ignition (distributor, 6 AL box, adjustable timing module). 10mm Taylor plug wires.
Holley reworked to flow 930 cfm. Edelbrock TM-6 manifold.
Hooker Super Comp headers and 3 inch exhaust through FlowMasters.
The engine runs really strong and smooth. Best ET in a mostly original and heavy 72 Charger is 12.40 with TCI 3500, standard 727, 4.30 gearing and slicks.
I think this motor could really wake up with a set of good alu heads so I need your tips folks.
I don't have too much to spend so I'm looking for the most bang for the buck
Thanks in advance
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Need 440 head tips [Re: HP2] #43205
07/14/07 06:17 AM
07/14/07 06:17 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
eddy's. if you spend a bit more, then the new MP heads. they have straight plugs for easier header fitment. although you can run other headers and even manifolds with the eddys, just very tight on the plugs/wires.
Re: Need 440 head tips [Re: Pool Fixer] #43206
07/14/07 06:36 AM
07/14/07 06:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Wait a few months and get a set of 440 Source heads.They will be just as good or better than Eddys and a lot cheaper.Rocky
Chrysler Firepower
Re: Need 440 head tips [Re: therocks] #43207
07/14/07 06:49 AM
07/14/07 06:49 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I went to their homesite but can't find anything..?
71 Duster 340
Re: Need 440 head tips [Re: HP2] #43208
07/14/07 06:55 AM
07/14/07 06:55 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
get a 6" carbide burr and a die grinder.
cost under a 100 bucks and some time.
you'll be surprized.
Re: Need 440 head tips [Re: theclutcher] #43209
07/14/07 07:07 AM
07/14/07 07:07 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Good idea theclutcher but the problem is that I don't have the time to do it
How much better are the Victors vs RPM's?
71 Duster 340
Re: Need 440 head tips [Re: HP2] #43210
07/14/07 11:17 AM
07/14/07 11:17 AM
About the 440source heads check out the "Moparts Hot Deals and New Products" section.
Re: Need 440 head tips [Re: HP2] #43211
07/14/07 11:30 AM
07/14/07 11:30 AM
State, country, etc.
gss Offline
gss  Offline
TM-6 fits a low deck B if I am not mistaken.
Re: Need 440 head tips [Re: gss] #43212
07/14/07 03:06 PM
07/14/07 03:06 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
You are right, the TM-7 fits the RB
Re: Need 440 head tips [Re: HP2] #43213
07/14/07 03:56 PM
07/14/07 03:56 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
Stock heads with oversize valves won't increase any horsepower or torque if nothing was done in the pocket to increase flow. The TM7 is down on torque, a RPM or a Holley Street Dominator would have been better. Here's what stock heads look like after they've been cut for oversize valves.
Engine by DeTar http://www.kansasbadman.com
Re: Need 440 head tips [Re: CH3NO2] #43214
07/14/07 03:57 PM
07/14/07 03:57 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
Here's what they look like when they are done
Re: Need 440 head tips [Re: joedust451] #43215
07/14/07 05:31 PM
07/14/07 05:31 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I gotta take another look on my intake tomorrow, if you say a TM-6 fits a B-block I beleive you...
71 Duster 340
Re: Need 440 head tips [Re: HP2] #43216
07/14/07 05:53 PM
07/14/07 05:53 PM
Vista, CA
71Chip Offline
71Chip  Offline
Vista, CA
If your pistons are somewhat close to zero deck you probably won't be able to run anything other than the performer rpm head or the 440source head (when it comes out) and run your car on pump gas. The 75cc chamber on the victor/indy heads would jump your compression up too high.
My neighbor went from stock 906 heads on his 440 6pack coronet to out of the box performer rpms. He is running a similar cam to yours, he only has 3.55s though. Just a street car, so no time slip comparison, but huge seat of the pants difference. I wouldn't be surprised if they were worth 50hp.
71 Challenger
Re: Need 440 head tips [Re: 71Chip] #43217
07/14/07 06:33 PM
07/14/07 06:33 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
I was just not at all happy with the performers.
That exhaust port blows and I wasnt impressed with the intake either even after carving them.
Ended up with a set of B1BS which I had never considered.
Wow in stock form good but my what potential,
ended up with 350 air on the intake!
Re: Need 440 head tips [Re: HP2] #43218
07/14/07 08:21 PM
07/14/07 08:21 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Fly me in and I'll do it for you! The victors have a bunch more potential than the RPMs but they also come with a higher price tag.
Re: Need 440 head tips [Re: Baxter61] #43219
07/15/07 07:14 AM
07/15/07 07:14 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I wish I could but if I would there wont be any money left for the heads
Looks like the 440 source heads is worth waiting for
71 Duster 340
Re: Need 440 head tips [Re: HP2] #43220
07/15/07 09:05 AM
07/15/07 09:05 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Right now? I'd definately go RPMs with nothing more than a correction valve job and some blending to get rid of the CNC marks. As for the 440Source stuff, I'm taking a "wait and see" approach, just like the blocks.
Re: Need 440 head tips [Re: moper] #43221
07/15/07 04:03 PM
07/15/07 04:03 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Why not the Victor's? Aren't they worth the extra $$$?
71 Duster 340
Re: Need 440 head tips [Re: HP2] #43222
12/02/09 08:21 AM
12/02/09 08:21 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
This thread started over two years ago and it has happened a lot regarding Mopar big block heads since then!
I haven't done anything to my beloved Charger since then, it still runs like a dream, but falls on it face above 5,000 rpm's.
I am still running stock 906 with the stamped original rockers, but now I think it's time to do something about it!
Some advice would be good though, most power for the bucks?
71 Duster 340
Re: Need 440 head tips [Re: HP2] #43223
12/02/09 01:22 PM
12/02/09 01:22 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
What ignition system are you running? what's the cureve? and was the cam degreed in? If so what did it go in at? Not that heads wouldn't improve your combo... but all done at 5K? Think there's more holding it back then the 906's
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
