Ball joint remover/installers need advice
#431930
08/08/09 10:56 PM
08/08/09 10:56 PM
Posts: 1,558 Midwest
Chargerfan
Midwest
Has anyone used the OTC kits from Sears? The one I was looking at had the C clamp and sleeves, but I don't see how you get that in there on a 71 Charger to get the joints loose. Any reccomendations that are affordable? Thanks
2011 Challenger R/T 2017 Ram 1500 BIG HORN Edition
Re: Ball joint remover/installers need advice
[Re: Chargerfan]
#431932
08/08/09 11:09 PM
08/08/09 11:09 PM
Posts: 320 Dallas, TX
71_Demon
Dallas, TX
Are we talkin' upper balljoints?
'71 Demon 383 auto
'12 Ram 2500 6.7 Diesel
[Re: 71_Demon]
#431933
08/08/09 11:13 PM
08/08/09 11:13 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Yes, he is talking about the uppers.
If you use a press you will ruin the control arms. Get the right socket.
[Re: WILD BILL]
#431934
08/08/09 11:23 PM
08/08/09 11:23 PM
Chargerfan
Midwest
Actually I am talking about seperating the joints not the removal of the ball joint, upper and lower. Sorry. Got to be an easier way than using a pickle fork.
[Re: Chargerfan]
#431935
08/08/09 11:51 PM
08/08/09 11:51 PM
WILD BILL
BROOK PARK, OH
The C clamp tool will not do that either. At work I seperate them from the spindle either with a pickle fork atttachment in my air hammer or simply by smacking the spindle with a BFH.
A couple good hits are usually all it takes just remember to remove the nut completly first, then rethread it back on a few threads so things don't get out of control.
[Re: VDART]
#431939
08/09/09 12:54 AM
08/09/09 12:54 AM
RapidRobert
on the upper take out the cotter key & loosen the castellated nut several turns & whack it in the side w a bfh & the suspension being in tension will pull them apart then undo everything & go from there
