Re: 80 chrysler lebaron 318 mileage improvement
[Re: 360view]
#431845
08/10/09 09:04 PM
08/10/09 09:04 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If you are getting 17 mpg on a 6 mile commute in the city.
You need to post on what YOU are doing, not asking us!
With number like that. I'm assuming you are already well versed at vacuum advance.
[Re: stage3]
#431846
08/10/09 09:25 PM
08/10/09 09:25 PM
Posts: 30,465 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
my city driving consists of a 6 mile trip one way back and forth to work(sometimes thermosat does not open till till 2-3 miles into journey) four times a day city driving with stop lights.
Have you checked to see if the crossover is plugged?
[Re: stage3]
#431848
08/11/09 08:09 AM
08/11/09 08:09 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
honestly, 17mpg in that commute in an M body is doing pretty good. I can't think of anything cheap to significantly improve this.
if you wanted to spend some coin, maybe try duplicate hotroddave's fuel economy build.....or at the very least, a 4bbl intake with a small q-jet or t-quad might give 1-2mpg better mileage than the carter BBD 2bbl you probably have, as long as you keep out of the secondaries.
[Re: patrick]
#431849
08/11/09 11:08 AM
08/11/09 11:08 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
A 6 mile commute with those numbers is very good. It sounds like you are getting about as much as possible now, so improvements from here are going to be tougher. I'd suggest trying synthetic lubes, an alignment, and decreasing the rolling resistance. What tires and pressures are you running? As mentioned, there are engine changes that can help, but at what cost? Raising the compression and installing EFI will cost ten times the 152 buck savings, when you consider tuning, gaskets and fluids and the parts. If you do go inside the engine, I'd also look at coatings. What engine temps are you seeing? Late model stuff is run very warm. If your cooling system can handle it, running warmer can get more MPG.
[Re: 440newport]
#431852
08/12/09 04:33 PM
08/12/09 04:33 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Station wagons usually had 3.21's so if you could find a Lebaron/Aspen or Volare wagon that would work.
Not necessarily. Dad had an 80 Diplomat wagon (318-2 non-Leanburn) and it had a 8 1/4" in it with 2.2 gears.
As mentioned, if you're getting 17mpg in 6 mile city commute, you're doing A-1. Don't even tune it up - don't touch it!!!
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: 71monaco]
#431854
08/13/09 10:06 PM
08/13/09 10:06 PM
Posts: 150 az
stage3
az
if you have a six mile commute, get a bike
Great idea..when it's 115 degrees out I'll draft off of you.LOL!!
