5.7 hemi/overdrivetrans #431014
08/07/09 10:59 PM
08/07/09 10:59 PM
ohio
Sherminator Offline OP
ohio
will the auto out of a twd truck fit in the tunnel of a 69 dart ?
Re: 5.7 hemi/overdrivetrans [Re: Sherminator] #431015
08/07/09 11:52 PM
08/07/09 11:52 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Very doubtful. The hemi truck trans is not small. The hemi car trans is much smaller but I don't know if that one would even fit without surgery. If you don't mind splicing and dicing, any of them can be made to fit.
Re: 5.7 hemi/overdrivetrans [Re: DaytonaTurbo] #431016
08/09/09 11:01 AM
08/09/09 11:01 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I'm not sure about A bodies, but I have a thread in the member build forum called "70 GTX-5.7 hemi Build".
I have pics posted showing a 5.7 with the w5a580 trans from a Charger R/T installed in the B Body. It shows what we had to do to the tunnel/hump at the transmission to get it fit in the car.
I'm guessing the A body would require at least that same amount of modification if not a little more.
Driving modern convenience in classic beauty
Re: 5.7 hemi/overdrivetrans [Re: Darius] #431017
08/11/09 01:50 PM
08/11/09 01:50 PM
ohio
ohio
ok i will go to that thread and look
