Dodge tech 99 Ram NoBus code?
#430962
08/07/09 09:54 PM
08/07/09 09:54 PM
Posts: 916 Arizona
Chucklehead
Arizona
My 99 Ram the fuel, alt, temp,speedo and tach will quit working and the odometer reads "No Bus" the lights, A/C, radio will still work then the gauges will start working after awhile. What does NoBus code mean? It stays on a few minutes and then the gages start working again.
Still Broke
Re: Dodge tech 99 Ram NoBus code?
[Re: Chucklehead]
#430963
08/07/09 10:02 PM
08/07/09 10:02 PM
Posts: 20,176 Park Forest, IL
slantzilla
Park Forest, IL
My '00 Dakota R/T acted like that when the PCM lost a connection inside it. NoBus is a communication error IIRC.
[Re: J_BODY]
#430966
08/08/09 10:24 AM
08/08/09 10:24 AM
Posts: 4,872 connecticut
pnypwr
connecticut
we had that in an 01 ram, there is the "twisted pair" that runs down from the ip panel tot he main harness, check there to make sure it hasnt rubbed thru, there is a series of diagnostic checks to test the condition if the ip cluster, but it sounds like a comm error either in the pcm or in the wires to the ip cluster
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#430967
08/08/09 10:38 AM
08/08/09 10:38 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have seen more problems with "Bus communication errors" in the instrument cluster than anything else and I have never seen one where it was the wire it self. I am not saying it is not the wire but it is pretty rare. BCMs are pretty common failure that can cause that but again not limited to them.
[Re: Pat_Whalen]
#430970
08/08/09 01:30 PM
08/08/09 01:30 PM
HotRodDave
Kalispell Mt.
If it is a sensor causing it you can try unplugging the sensors one at a time and see if it will restore comunication, when comunication comes back you will know witch sensor s bad.
[Re: 69MOPE]
#430972
08/08/09 05:58 PM
08/08/09 05:58 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
I have had internally shorted cam sensors (4.7L engine), crank sensors and A/C transducers cause the NO BUS code.
Yep, any sensor that's shorted will drag down your reference voltage and invariably bring down the BUS.
