Dana 60 Pinion snubber height (will aftermarket fit?) #430555
08/07/09 12:16 PM
08/07/09 12:16 PM
BDW Offline OP
BDW  Offline OP
I'm looking at the American Muscle part, from the pics it looks like the height is at least 5-6" when at the lowest position.
The factory part only looks to be 1" max.
Looking at the clearance I have in the car, maybe 4-5".
Anyone have experience with these on a 70 Challenger?
Thx
Re: Dana 60 Pinion snubber height (will aftermarket fit?) [Re: BDW] #430556
08/07/09 12:22 PM
08/07/09 12:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You will need alot of spring arch to get that to fit under floor. I've had to cut down most of the mopar adjustable snubbers on mine for mp springs.
Re: Dana 60 Pinion snubber height (will aftermarket fit?) [Re: BDW] #430557
08/07/09 12:55 PM
08/07/09 12:55 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I had an American Muscle snubber at my disposal a couple of weeks ago. There's no way it was going to fit on my wife's '70 Barracuda with Mopar XHD springs. The snubber was much too tall.
I just cut down a spare MP adjustable snubber in the meantime. (I'm working towards getting Cal-Tracs on the car.)
Re: Dana 60 Pinion snubber height (will aftermarket fit?) [Re: Blues_Cuda] #430558
08/09/09 12:05 PM
08/09/09 12:05 PM
BDW Offline OP
BDW  Offline OP
Sounds like I need the stock style.
Anyone know if the rubber on the stock part is replaceable? Would it be possible to add another taller piece if you wanted to limit upward travel?
Thx
Re: Dana 60 Pinion snubber height (will aftermarket fit?) [Re: BDW] #430559
08/09/09 01:59 PM
08/09/09 01:59 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Year One has the replacement rubber snubber. You might be able to add a spacer under the snubber rubber, but I don't think it will allow much additional height.
Do you have the reinforcement plate that is welded to the bottom of the floor pan?
Re: Dana 60 Pinion snubber height (will aftermarket fit?) [Re: Snoopy] #430560
08/09/09 06:08 PM
08/09/09 06:08 PM
BDW Offline OP
BDW  Offline OP
Thx for the info,
I can't tell if there is anything welded to the floor, not all cars have this plate?
What would it look like?
Re: Dana 60 Pinion snubber height (will aftermarket fit?) [Re: BDW] #430561
08/09/09 06:23 PM
08/09/09 06:23 PM
Snoopy Offline
Snoopy  Offline
Re: Dana 60 Pinion snubber height (will aftermarket fit?) [Re: Snoopy] #430562
08/09/09 08:12 PM
08/09/09 08:12 PM
BDW Offline OP
BDW  Offline OP
You sir are a wealth of information.
Thanks for the help!
Re: Dana 60 Pinion snubber height (will aftermarket fit?) [Re: BDW] #430563
08/09/09 09:56 PM
08/09/09 09:56 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
On my 68 Coronet, the MP adj. snubber unit would barely fit. I went back to a stocker.
