gear lube #430194
08/06/09 07:23 PM
08/06/09 07:23 PM
cmansell Offline OP
cmansell  Offline OP
I need to replace the lube in my 2003 ram 1500 4x4. It's at 76k mile and starting to have a shudder at slow speed takeoff. It was serviced once at the dealer at about 30k miles. Its a 3.55 suregrip rear. Any suggestions?
Re: gear lube [Re: cmansell] #430195
08/06/09 08:36 PM
08/06/09 08:36 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Re: gear lube [Re: 67_Satellite] #430196
08/06/09 08:44 PM
08/06/09 08:44 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
dont forget the suregrip additive
Re: gear lube [Re: 67_Satellite] #430197
08/06/09 10:19 PM
08/06/09 10:19 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Straight ahead or cornering? can't imagine gear lube having anything to do with it unless cornering. Manual or automatic? Clutch and/or engine/transmission mounts I'd check also.
Re: gear lube [Re: DZJim] #430198
08/07/09 06:58 AM
08/07/09 06:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive seen them shudder from old lube.Had one at the shop that I swore had a bad rear.Changed the lube and added the lube it was an older model.Cured it right now.My kid just bites the bulley and gets the Mopar lube that it takes.For a few quarts its cheaper than buying a rearend.Rocky
Chrysler Firepower
Re: gear lube [Re: therocks] #430199
08/07/09 08:19 AM
08/07/09 08:19 AM
cmansell Offline OP
cmansell  Offline OP
yes straight shudder like in a level parking lot, when it just barely moves I feel a shudder but it won't if under load seems like. Iwonder If we know who makes the stuff dodge sells?
