Dealer Tech help for 2002 mini van cruise control #430149
08/06/09 04:54 PM
08/06/09 04:54 PM
Rochester Hills, Michigan
64KBF Offline OP
64KBF  Offline OP
Cruise light comes on but goes off and will not engage control system and therefore does not work.
Re: Dealer Tech help for 2002 mini van cruise control [Re: 64KBF] #430150
08/06/09 06:28 PM
08/06/09 06:28 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
Mine does the same thing! I have replaced the servo, brake switch, both steering wheel switches, main relay, clockspring and flashed the body controller. Still does it! It will work the first time in the morning but shortly after using the brakes the light goes out and won't come back on until the van sits for a few hours with the key off. If someone here can help you, they will be helping me also.
Re: Dealer Tech help for 2002 mini van cruise control [Re: 69MOPE] #430151
08/06/09 06:56 PM
08/06/09 06:56 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
This isn't the full procedure, but if it only happens after applying the brakes (second post), it might be the brake switch. These supply power to the actuator, and the switches can go bad. I've read that they are a one time install, so if you remove it, it has to be replaced.
Re: Dealer Tech help for 2002 mini van cruise control [Re: RodStRace] #430152
08/06/09 10:10 PM
08/06/09 10:10 PM
64KBF Offline OP
64KBF  Offline OP
Bump
