holley blue pump #430126
08/06/09 04:43 PM
08/06/09 04:43 PM
port alberni CAN.
BLACKFISH Offline OP
port alberni CAN.
just started leaking out a bypass hole on the body above the impeller. anybody got any ideas before i drain the tank to take a look? pressure relief stuck maybe?
Re: holley blue pump [Re: BLACKFISH] #430127
08/06/09 08:47 PM
08/06/09 08:47 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Junk it...... It is a seal that is pressed in and you can't replace it I've been there done that.
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: holley blue pump [Re: Butch] #430128
08/06/09 10:30 PM
08/06/09 10:30 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I second the motion. Been there-done that too.
Yeah, it's got a smallblock.
