Jetting my 800 DP.
#429672
08/06/09 12:56 AM
08/06/09 12:56 AM
Posts: 1,760 Port Alberni, British Columbia
MoparDonny
Hi guys. I don't get to do much tuning for 1/4 mile times around here so I'm looking for a shortcut...... imagine that My 4780-1 came stock with 70/76 jets and so far I've changed it to 70/80. Never ran it stock. My 440 has run a 12.37 at 110 the way it is but the jetting numbers look lean and the plugs are clean. Since I'll only have 3 or 4 chances to tune at the track I'm looking for the fastest approach to the best full throttle power, not too worried about driveability at the moment. I was going to put 74's in the front and if it picks up I'd put some 82's or 84's in the back and see how it does. Which end should I concentrate on, front or back or a little of each? It's a 509 cammed 440, TM7 single plane intake with a 1 inch spacer, 452 heads and 1-3/4 headers, 3200 stall and 3.91's with 26 inch tires. ANy thoughts? Don.
Re: Jetting my 800 DP.
[Re: Cab_Burge]
#429680
08/07/09 11:29 PM
08/07/09 11:29 PM
[Re: MoparDonny]
#429681
08/07/09 11:38 PM
08/07/09 11:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I am using both powervalves. I might throw the 74's in the front on Saturday morning before some time trials and see how it likes them.
Don
If you are running PV in both the front and rear why the big difference in jetting..... it pulls the same amount of air through the primaries
[Re: VernMotor]
#429684
08/10/09 04:03 PM
08/10/09 04:03 PM
MoparDonny
Well....... I don't recall exactly why I put 80's in the rear . I think It was a morning run I made a couple years ago and it didn't hurt anything so I left it cause the plugs had looked too light previously. I tried 74's in the front on Friday night at home and the engine didn't like it even in Neutral, it sputtered until it was really revving. Put the 70's back in and all was good again. I never had a chance to play with the jetting on the weekend, I was fighting some pinging issues so I had to get that sorted out first and I ended up breaking out in the Third round on Sunday by .04 on the brakes. I don't know why the car always gets faster Sunday afternoon but I was taking .05 off my dial every round and still letting up at the top end. So I really didn't accomplish much in the jetting end of things but had fun none the less. Thanks guys. Don.
