compression ratio #429573
08/05/09 10:41 PM
08/05/09 10:41 PM
grant louisiana
mayhem148 Offline OP
grant louisiana
is there a way to tell comp ratio without pulling the heads.
Re: compression ratio [Re: mayhem148] #429574
08/05/09 11:20 PM
08/05/09 11:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes... But you probably don't want to buy the equipment...
http://www.katechengines.com/corporate_services/whistler.php
Your best chance is to go to a stock car or SCCA class race & talk to the tech inspector. Most inspectors have the equipment & know how to use it accurately... Now the trick is getting him to use it on your car...
Re: compression ratio [Re: 1_WILD_RT] #429575
08/05/09 11:32 PM
08/05/09 11:32 PM
grant louisiana
grant louisiana
i dont need to know it that bad. but there is dirt tracks all over around my place and ill bet someone has one of these things.
Re: compression ratio [Re: mayhem148] #429576
08/06/09 07:18 AM
08/06/09 07:18 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Compression test and cam knowledge are starting points. and you altitude
Re: compression ratio [Re: Dodgem] #429577
08/06/09 07:54 AM
08/06/09 07:54 AM
grant louisiana
grant louisiana
so it can be done at home with pen and paper. and thats another thing. i dont know how i can find the duration of the cam. i inherited this car and the guy that built it died so i have know idea whats inside. i know its had after market pistons cam and machine work.
Re: compression ratio [Re: mayhem148] #429578
08/06/09 08:58 AM
08/06/09 08:58 AM
As said pay one of the circle track tech inspectors to pump it up for you. In the meantime as said a compression test will tell you what your dynamic CR is and therefore what your gonna need for fuel which is the bottom line
