dp4b question #429183
08/05/09 02:26 PM
08/05/09 02:26 PM
Iowa
P
plumcrazyb Offline OP
P
Iowa
Is there suppose to be a small round hold on the underside? Light doesn't go thru to the runners/exhaust crossover.
Re: dp4b question [Re: plumcrazyb] #429184
08/05/09 03:09 PM
08/05/09 03:09 PM
scratchnfotraction Offline
egr port?
blow air through it...
if it egr it can be pluged
Re: dp4b question [Re: scratchnfotraction] #429185
08/05/09 03:13 PM
08/05/09 03:13 PM
JOPLIN MO 64804
RBDART1 Offline
RBDART1  Offline
JOPLIN MO 64804
Lookin for that same intake for a 273,anyone???thanks....
Re: dp4b question [Re: RBDART1] #429186
08/05/09 03:40 PM
08/05/09 03:40 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not hardly - DP4B is a BB intake. CH4B is for the RB engines.
Re: dp4b question [Re: MoparforLife] #429187
08/05/09 03:42 PM
08/05/09 03:42 PM
you want the LD4B for 273,and a LD340 will work also..
Re: dp4b question [Re: scratchnfotraction] #429188
08/05/09 03:44 PM
08/05/09 03:44 PM
Upper Midwest
Upper Midwest
Also an early D4B for the early 273.
Re: dp4b question [Re: MoparforLife] #429189
08/05/09 03:55 PM
08/05/09 03:55 PM
Re: dp4b question [Re: plumcrazyb] #429190
08/05/09 11:44 PM
08/05/09 11:44 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
dp4b = 383 / 400 cid intake !
small hole goes through to top side as there is a tube in there to pick up heat for the choke on a 780 holley .
