I am working on building my exhaust and was eyeing up where I was going to weld in my sub-frame connectors.
If I am not mistaken I have a brake line on the driver side, fuel line on the passenger side and the emergency brake cable in the way.
The rear looks fine, I think it SHOULD be pretty straight forward.
What would you guys do with the sub-frame connector mounts at the front? (up by the torsion bar mounts)
My plan was to use 2" x 3" Rec. tube, insert it inside the rear subrame and rear floor board. As you can tell by the pictures I have to replace my front floor pans, So I was woing to do this all at one time. (Front floor pans and sub frame connectors).
What would you do with the brake cable/lines and fuel line?
