trouble removing tranny #428685
08/04/09 05:25 PM
08/04/09 05:25 PM
Colorado
P
PlumCrazyFury Offline OP
P
Colorado
Hi everyone,
I am taking the a904 out of my 71 dart. Everything is disconnected accept the torque converter bolts. it is being safely held in place. I have it in neutral but cant seem to turn the converter to get to the bolts. battery and starter are disconnected so i cant bump it over. help
Big Block to the Rescue!
Re: trouble removing tranny [Re: PlumCrazyFury] #428686
08/04/09 05:41 PM
08/04/09 05:41 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
put a scoket on the front balancer bolt and turn clock-wise and it will spin. a helper helps.
joe
Re: trouble removing tranny [Re: skajm] #428687
08/04/09 06:12 PM
08/04/09 06:12 PM
scratchnfotraction Offline
remove the starter and pry it over with the tip of a screw driver
use the block edge for leverage,stick tip of flat screw driver in teeth of ring gear on verter
not that hard unless an engine is locked up..
starter has to come off any ways,a small c-clap will help hold the verter in the tranz while you man handle it out from under the car
Re: trouble removing tranny [Re: scratchnfotraction] #428688
08/04/09 11:51 PM
08/04/09 11:51 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
And take the spark plugs out.
