Moroso Water Pump Drive
#428467
08/04/09 01:04 PM
08/04/09 01:04 PM
Posts: 1,532 off the grid
340B5
off the grid
I was wondering of anyone using the Moroso external electric water pump drives has any problems with overheating down-track or even in the staging lanes when it's stop and go. I was thinking of using the 28% overdrive pulley on the motor, but still water flow only comes to 11.2 gpm., that isn't very much.
Yeah, it's got a smallblock.
Re: Moroso Water Pump Drive
[Re: 70dusterjohn]
#428471
08/04/09 01:26 PM
08/04/09 01:26 PM
340B5
off the grid
Did you use the standard 11 cog pulley on the electric motor?
[Re: dOc !]
#428473
08/04/09 01:31 PM
08/04/09 01:31 PM
340B5
off the grid
This is for strip only. It would work fine in staging lanes when there are even slight delays, but sometimes it's stop and go.
[Re: 70dusterjohn]
#428476
08/04/09 01:43 PM
08/04/09 01:43 PM
340B5
off the grid
That's my situation. I get laid off every 4th or 5th week and looking to save a buck, but not at the expense of a set of rings. What engine do you run, that could make a difference. Mine is a smallblock.
[Re: 70dusterjohn]
#428478
08/04/09 02:03 PM
08/04/09 02:03 PM
340B5
off the grid
Thanks for the info. Mine is 11.90's car and probably about 1/2 your HP. Still undecided,but I know the self-contained unit would be the safe way.
[Re: 340B5]
#428482
08/04/09 04:15 PM
08/04/09 04:15 PM
Posts: 136 Dallas, TX
440Brian
Dallas, TX
I use one in my (11.1 sec) 440 bracket 70 Duster. I run a viscous fan, stock WP, OEM type replacement radiator (2 row? for a non/ac small block), and a 160 deg thermosat. In the heat of the Summer down here, I stage about 180deg, and drive back to the pits at about 225. I'll run the fan/WP while waiting in the staging lanes, starting it to move forward. Back in the pits, I run it for about 10 minutes to get it back to 160 degrees. I run a single battery with an alternator, plus I charge it between runs.
